Boost gauge advice
Boost gauge advice
just got my a pillar trims back from r and b motorsport, all modified and ready to accept my 60mm apexi gauge.
cheers mike they look wicked
just a quick question, when it comes to fitting, wheres the easiest place to take the light feed from (illumination) closest to the a-pillar.
Also where is the best place to t-off for the bosst hose? on the ecu hose, FPR hose etc?
cheers guys
rory
cheers guys
rory
Re: Boost gauge advice
cheers guys
rory
cheers guys
rory
You need to tee into the vacuum take off that feeds the dump valve. This is usually the one to the left of the brown ACT sensor in the middle of the plenum. Do not use the fuel pressure or the MAP sensor ones, as you don't want to run the risk of anything going wrong with these (by creating three additional areas it can leak from).
Glad you're happy, invoice will follow shortly, as I'm a few days behind at the moment .
cheers guys
rory
cheers guys
rory
WHERE DO I FIND THIS FEED CLOSEST TO THE A-PILLAR, BEHIND THE CLOCKS, IF SO WHAT COLOUR
WILL HAVE A LOOK FORTHIS TONIGHT, ITS BLANKED AS I HAVE NO DUMP VALVE
[CHEERS, its all paid for already
You need to take the feed off the lighting circuit, so that backlight only comes on with lights.
There is sidelight (grey/yellow or grey) and earth (brown) on the back of any of the 4 switches to the right of the instrument cluster.
I know, I just haven't sent your invoice yet
rsguy
44
29-09-2015 03:29 PM
Russ Payne
25-09-2015 08:29 PM
