nitrous oxide...
Old Aug 7, 2006 | 11:06 PM
gordyshreds's Avatar
gordyshreds
Default nitrous oxide...
does anyone in here use it???Views????
Old Aug 7, 2006 | 11:17 PM
Yes, ive used it on many cars, both of my own and for others, what would you like to know about it?
Old Aug 7, 2006 | 11:31 PM
Alg1k's Avatar
Alg1k
i have used it in the past but now i have a waisted spark ign system am a little scared to
Old Aug 7, 2006 | 11:33 PM
JonnyBravo's Avatar
JonnyBravo
I've used it without any problems.
Chips your man on the subject tbh.
Alg1k- whats the issue there then ? Surely some of this American toss runs wasted spark without any problems ?
Old Aug 7, 2006 | 11:39 PM
Alg1k's Avatar
Alg1k
waisted spark means that 2 cyl fire simultainiously ie 1-4 2-3
When No 1 is on its power stroke when you have very long cams no 4 inlet valves can be open thus some of the nitrous is exposed to a spark and can blow your inlet .boost hoses and split your intercooler
oh yes and bonnet off
Old Aug 7, 2006 | 11:43 PM
JonnyBravo's Avatar
JonnyBravo
That ofcourse makes sense, I'm just curious of how other get around this ?
Surely quite a lot of modern engines are running wasted spark these days and people still Nitrous them.
You do sounds like you have had a bad experience though
Old Aug 7, 2006 | 11:49 PM
Alg1k's Avatar
Alg1k
R THEY USING VERY LONG DURATION CAMS
Non of this off the shelf shit
Old Aug 8, 2006 | 07:52 AM
Were you running sequential ignition? cause if not i fail to see why you dont get a backfire off gas as well as there would still be a spark on that cylinder and still be fuel present?
On the subject of cams, typically most modern engines are tuned around short duration big lift, and thats usually even more the case on the inlet side of an engine specced to run nitrous.
FusionRS
Oct 14, 2005 06:33 PM
gurnE
Oct 6, 2005 10:29 AM
chris-m
15
May 27, 2005 02:32 PM
44
Mar 10, 2005 11:26 AM
22
Jan 4, 2005 11:51 AM
