Best head gasket for around 380-400hp?
saff is working!!!...atm
just logged on 2 ask the same question ive already got a group a,but ive been told 2 get a cometic one....but my pal told me he'd heard bad reports,its been long studded,so what do we buy?????
Funny my cometic gasket let go about 500 miles ago and its only done 8k total now.
Wire rung and 611 for me I think - and I run over 400 horses.
Fair do's a wrc is fit and forget but if I want to do the gasket myself in future I can once its wire rung.
With the WRC gasket the block and head need to be faced.
Jake
Jake
I bought my headgasket from Italy, it's called Navalinea sport. It was 180euros and the price includes "group a reinz style" normal gasket and stainless rings (coopers?). I was going to use cometic in the beginning but since few of my friends have had problems with them almost all of them have changed to the stainless ring type gasket and for now, no problems with them (+500bhp ~2bar).
I currently have standard headgasket, standard bolts, 400bhp/540Nm and 22psi. And it is ok...but who knows how long. When the winter comes, I'll put the engine in pieces and I change the new gasket in.
Jasus thats great news. I've just fitted a Cometic head gasket and i'm going for 330 in a few weeks ! It'll have to do until it blows, i ain't taking it back out now. Anyone on here had no problems with them ?
just finding my feet
cant be mate as the reinz is a group a,,,,,, hes is a copy of a group a gasket
thats what i used but,,,,,,,,,,, well my engine aint done a revolution since i timed up the cams
Cometic or WRC are effectively the same thing in that both MUST HAVE perfectly flat surfaces to mate to, and if done correctly like that both will take an enormous level of punishment
Mine most certainly has not had what I would call an " enourmous level of punishment "
Far from it in fact.
Stu uses them frequently on big power engines for example without any problems.
If the surfaces arent flat, it WILL blow, and fairly soon even at moderate power levels.
Again I am going to disagree with you 100% again- I know for a fact both head and block where correctly faced.
These things happen though..
I'm defo not putting one back on my car,
J
Originally Posted by yrkesman
I bought my headgasket from Italy, it's called "group a reinz style" normal gasket and stainless rings................
As well as the YB-0611 (known as the "Group A" gasket) they also produce the late Es Cos YB-1261.....Look for "Victor Reinz" printed in black all over the bottom (block) face....(see pic below).
If you use "O" rings then cheap YB-1261 is a very good choice, it looks better constructed than the 0611.
YB-1261 is less than quarter the price of "Group A" YB-0611 too.....
Okay, my post was once again misleading I meant that the Italian gasket uses headgasket with cooper rings. I don't think the italian version has nothing to do with reinz, since I think the "main" gasket is one of their own made. I just tought it might be worth to try the Italian version since it is much cheaper than the wrc version and it seems to cope with quite much power.
link for the small turbo ones for sale mate please
Originally Posted by b19bal
......link for the small turbo ones for sale mate please
Burton Power
P J motorsport
Available from your local Ford dealer but only as part of a FULL head-set purchase.
Also available from one or two E-Bay specialist gasket traders.........BUT be sure to order their "cheap" or "standard" gasket or head sets (not Group A or Cometic sets), and check with the seller that they are Victor Reinz 1261 before ordering.
Rog if fitting wrc/cometic multi layer gasket,advise at least arp head stud/nut kit,but better with long studs,donot use standard head bolts
cheeRS stu
cheeRS stu
cheeRS Stu
cheeRS Stu
Originally Posted by tregmatt
id go 4 a wrc item thats what i have on my 530+ escort cossie and havent had no problems since having it fitted
CUNT!
Location: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
Copper gaskets are exceptionally good! I've made quite a few over the last few years (although not for Cossies). The ones we sell are guaranteed against failure
K155MYRS
If the Cometic one goes (the newer updated ones) than it's on wrong. The Cometic is a nice piece but as with all MLS gaskets, it might be too good. If the gasket doesn't blow then something else in your engine will.
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
