4x4 driveshafts
4x4 driveshafts
daft question just had 2 recooned by amk and they have given back new units ....1 is longer than tother does the longer 1 go in the drivers side front???
Passion for Fords!
i couldnt use the xr shafts with my koni -25mm suspension so had to use standard shafts, now with coilovers i can run a bit lower so the xr shafts fit fine with no probs.
If you have one long shaft and one short one, the long one should go on the o/s as thats the one that causes most problems ,
07-10-2015 12:56 PM
