ST170 Brakes on ERST (Goodridge hoses won't stop leaking)
Has anyone else had any problems when fitting ST170 front calipers??
I've used Escort RS Turbo Goodridge Hoses all round but can't get them to seal where the hose goes into the caliper.
Do i need to use ST170 brake hoses? Standard ERST hoses??
I don't know.
Matt.
I don't know.
Matt.
id like some info on this as im about to fit the ST170 conversion on mine with RS Turbo goodridge hoses...! So any info would be great guys!
Yeah i've ditched my ABShit as well.
I'm not sure i have them the right way round now.
The Metal pipe has a dished end so i fitted the end of the Goodridge hose that was most suitable to that. (hope that makes sence)
Cheers Jano,
I'll have to inspect them tonight.
The hoses clamp right into the caliper and are only sealing on the copper washer that was on the hoses.
Thanks.
Thanks.
My mate has ST170 calipers with Goodridge braided hoses with no problems! If the hoses have been used previously then the copper washers should be replaced after every time they hoses are nipped up as they compress/squash to form the seal.
If they are brand new then I don't know
HTH's
HTH's
Originally Posted by Gadget
I'm with jano, i reckon Zvh is putting them in the wrong way round! the short end should go to the brake pipe!
I think the hole in the ST170 calpiers is drilled a bit deeper and thats why i'm not getting a seal.
Thanks for all your help guys.
Matt.
borboyous
22-08-2015 11:17 AM
Palethorpe01
15
18-08-2015 06:09 AM
track.focus'd
12-08-2015 05:53 PM
