~PAS question ~
Old Jul 31, 2006 | 10:29 AM
gingeRS's Avatar
gingeRS
Default ~PAS question ~
have discovered a power steering fluid leak and have the hose off to replace it (will call the breakers to find another)
now......whats the name of the fluid to refill it with when fitting? is it juast ATF fluid or is there some thing more specific i should look for?
also, how do you bleed the system, after filling it up, just go from lock to lock, or is there another way?
cheers
Old Jul 31, 2006 | 10:31 AM
SapphyMike's Avatar
SapphyMike
usually dexron III. its a red colour..
Old Jul 31, 2006 | 10:39 AM
gingeRS's Avatar
gingeRS
cheers
is that castrol???
Old Jul 31, 2006 | 11:29 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
atf is fine..... to bleed it its best to work it lock to lock with the engine off first or the air can damage the pump, maybe easier to jack it up for this, then get it running lock to lock a few times and top up the level.
Old Jul 31, 2006 | 01:39 PM
gingeRS's Avatar
gingeRS
its on axle stands with no front wheels at the minute.
so turn it lock to lock with engine off? and then start it up and check the level?
cheers
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
