Help Escort RST has just died
Anyone know wot might be wrong with my RS
Just took it out and noticed it pissing out oil so checked under the bonnet and the dipstick had shot out , Decided to get it home and everything dropped it wouldnt go no faster then 30 and was coughing and spluttering, then just cut out and now wont start at all not even turn over
Cheers in advance
Cheers in advance
Yup, you've got no rings left or something similar. Either way oil is being pressurised in the sump by combustion gases in the cylinders, which aint good.
You wont be able to do a compression test if he says it wont even turn over.
Sounds like if it has drained all its out the dipstick then theres a possibility that its seized
Hold on, you noticed it was pissing oil out so decided to drive it home?????????????????????????????????????????????
Yup fooked....................
But cant help but to say why the hell did you drive it home???????????
Guest
Posts: n/a
oil light on when you drove back? if so as above, but i once had a lobe on the cam go in my 1900t very simlar symtoms "pop bang pop bang big fuck off clouds out the back pop bang") 30 mph is your lot sir sounds like head off to check, does it have a dump valve? they shower oil all over the engine when a turbos seals go, hope it aint to bad mate
JK12
33
26-04-2021 12:09 PM
