please help and tell me what these figures are for a 2.1 zet
ok can anyone please help and tell me what these figures are for a 2.1 zetec turbo engine as someones making me a map but i dont know figurs below
its a 2.1 zetec turbo, the engine was a 2.0 mondeo
3) Factory timing settings for Idle , max advance ?
4) Stock and/or esitmated idle speed ?
5) Stock idle vacuum (manifold pressure) ?
6) Max boost you think you will really ever have. Really.??
Re: please help and tell me what these figures are for a 2.1
What a scary concept.. maps by post!! Anyway.. here goes..
You really want to go for say the stock ford table in the vacuum area.. idle around 5-6 deg.. max advance where?
~850 rpm
~30-40 kpa
Only you will know the answer to this.. 1.3 bar with the right turbo will see you 300bhp..
Originally Posted by rsguy
i gather its ignition max advance mate
hmm..
This is a dodgy topic with a lot of well suspect questions on it.
The answers are all TOTALLY dependant on compression/head ports/cam aggression and timing and the above figures may either:
1) Be fine.
2) Not even idle
3)Destroy your engine if you interpret the advance answer wrong.
Take care. get it done PROPERLY.
1) Be fine.
2) Not even idle
heres my current spark table
I would also space the map very differently from the start. Half your breakpoints are now above 5000rpm and they are not very useful there. And what's this with zeroing everything above 150kpa?
JoeyBoyden
04-01-2024 02:36 PM
Rsmat
42
01-09-2015 09:39 PM
