Any bike riders who can help....(pedalbike that is)
Right i think my spindle bearings on the rear wheel is broken, well actually im sure it is....
Can i buy a new bearing or do i have to have a new wheel?
Also where can i buy the bits from....?
Depends mate, you need to strip the wheel bearings/spindle out and have a look, for this you need cone spanners. Hold cone (the one under the locking nut) with the cone spanner, then loosen the locknut, take thet off plus the washer, and cone.
Then you should see your bearings, gently remove the spindle from the side youve not been working on. Remove the bearings from the cups there should be 11 either side, inspect cup races for excessive pitting/ scoring, also inspect the bearings for same.
Chances are if you dont service your wheels regularly, then the are fucked, you can replace the bearings and cones but if cup races are pitted you are papering over the cracks.
TBH you are better buying a new wheel from fleabay
Fuck you lot lost me at "depends"
Right, will get a pic up later on, but it is only a secondhand bike i bought off a mate for 70 nicker, is it worth repairing/new wheel...?
Went to pull away from a stop, put some presure on the pedal and it just clicked and wheel went wonky and has broken away from the spindle and all the ball bearings are showing..............
Arse why do these things always happen when i alreday have enough on my plate..........
![Bat](https://passionford.com/forum/images/smilies/pascontent.gif)
correct, so new/second hand bike time then......?
Any advise...
Do about 20-25 miles a day....
Could do with somehing that will be able tobe chucked about and dont really want full suspension........
If i went looking id just buy the prettiest looking one
Any advise...
If you are using it mostly on the road, and a bit of offroad, get front sus mountain bike get a nice one for buttons on e-bay, if you do pm me and i will send you a size guide so you dont get one that doest fit! (very important)
That looks and sounds
Will give it ago, how much do you think it will raise as i need it asap and might make him an offer to end early....?
STAFFY OWNER
13-09-2015 08:59 PM
