do cambelts jump teeth??
As above coz when i had my car set up at paul hills,engine advantages, The cambelt was one tooth out.....he adjusted it back to where it should be which i witnessed but when i took my head off last week it was misaligned again....WTF is going on. Is there a reason for this??????
Are you sure it's out?
whats it running like?
cos if someone has used paint parks on the belt and you are going by these they'll never line up again, well they will, but it's something like 52 turns later.
when i took the head off last week i lined up the crank marks with the timing pulley but the pointers on the cam pulleys were not directly opposite each other.....they were both pointing upwards by a tooth or so
i don't really undertstand what you've done tbh?
you had it setup and matey said it was 1 tooth out so he adjusted, you took the head off last week and then it was out still?
is that right?
do you have different cams/vernier pulleys?
is that right?
The belt was about 1 month old (gates) when you bought it mate ?
I really had no idea i was running about in it with 1 tooth out as you said
Strange its out again though ?
Hope everything turns out ok
