removing rear diff?
Old Jul 21, 2006 | 06:18 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default removing rear diff?
not from a cossie but from a 2.0l ghia 8v twin cam jobbie
i know cossie half shafts bolt to the diff, but this un doesnt. do they just pull out like 3 bearing driveshaft or are they splined ones and pul out
or whatever?
would like to know asap too as ford fair is only 2 weeks away, and i only have this week to piss about with it
also, anyone know the size of the clutch for the above??
cheeers
Old Jul 21, 2006 | 09:34 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
aaaaaaaaaannnnnnnnnnnnnnnnnnnnyyyyyyyyyyyyyyyyyyyy yyooooooooooooooooooonnnnnnnnnnnnnnnnnnnnnnnnnnnee eeeeeeeeeeeeeeee??????????????????
Old Jul 21, 2006 | 09:38 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you've got a drumed rear diff mate
so it won't fit your driveshafts
in other words, you is fooked
unless you find a discs rear diff
the ratio is going to be a 3.92 and it SHOULD be a 7.5 inch diff
the dohc twinky uses a 220 odd mm clutch
Old Jul 21, 2006 | 09:47 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
why am i fooked?
i wanna take the fukker off and get it welded lol, so it will be going back on.
yes it has drums at the rear too, but i just wanna know if the shafts pull out.
cheers for the size of the clutch tho, looks like the cheapo ones on egay aint the ones lol
Old Jul 21, 2006 | 09:53 PM
dojj's Avatar
dojj
yup, the shafts just pull out with a bit of a yank
thought you had a grann rear end on it?
or is that someone else?
Old Jul 21, 2006 | 09:57 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
for my project 3dr i got proppa 2wd cossie stuff
but the new fast ford project car is 2.0l ghia lol
and yes, its gonna be a drift car hence the welded diff
just gotta learn to drift by ford fair lol so i dont look a complete cunt
that gives us 2 weeks
Old Jul 22, 2006 | 09:14 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
right, beofore i get the tools out lol
i need to undo the 4 bolts holding the diff hanger to the chassis, that will drop the diff down, will i then be able to lever out the half shafts with it still connected to the prop so i dont do a spadge?
or will it twat me on the heed anyway?
Old Jul 22, 2006 | 09:16 AM
Graceland's Avatar
Graceland
Team HOTHOT!
you need to unbolt the bearing carriers from the rear arms, then pull on them, this will pull them out of the diff
tip tho - undo the prop bolts first or you will struggle
Old Jul 22, 2006 | 09:29 AM
smithy20vt's Avatar
smithy20vt
Fudgey you cunt you ve killed another car then
Fudgey's Avatar
Fudgey
Baby Cheesus
lol ok, so remove prop, undoe rear arm bolts, undo diff hangar
and the lot falls on the floor?
Old Jul 22, 2006 | 09:30 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
no mate, taking it off to get welded
Old Jul 22, 2006 | 10:27 AM
dojj's Avatar
dojj
don't forget that you've got to remove the drums in order to get to the bolts you need to undo
there are holes in the hubs so you can JUST about squeeze a 13mm socket through to get to them
then it's just a yank and it's out
but, as gracy says, if you haven't undo the prop you be in a bit of bovver
Old Jul 22, 2006 | 10:31 AM
CozzyBrom's Avatar
CozzyBrom
you carnt weld that diff up it will snap them shafts like carrots
just go scrapper and get a granny rear set up with disc brake rear get full beam for Ł30
Old Jul 22, 2006 | 12:42 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
well, rain stopped play lol
the heavens opened and i got fooookin drenched
and marble size hail stones fookin hurt too
i undone the prop, peice of piss with an impact wrench, and then undone all the bolts holding the diff in the beam, but getting the long bolt out was a right a cunt and took me 1/2 hour to beat it out
i unbolted the rear shock on the drivers side, and you can almost lever the shaft out, but not quite.
so i started to undo the swing arm, but you cant push the outer bolt out as it hits the chassis, and that about as far as i got
dojj, if i take the drums off, wont i still need to take the swing arm off to pull the shaft out?
brom, peeps on trampdrift are using the std 2.0l jobby welded up with no probs.
if it breaks, we will get the granny stuff lol
ill have another go tomoz lol
Old Jul 22, 2006 | 12:59 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
cant you just weld it in situ? is that not possible?
Graceland's Avatar
Graceland
Team HOTHOT!
on drums, you do not need to remove the swinging arm, just the hub carrier that bolts onto the swinging arm, as the tripode joint is thin enough to pull thru the hole in the arm
Old Jul 22, 2006 | 01:01 PM
CozzyBrom's Avatar
CozzyBrom
well we used to weld um up stock cars cuz they always broke
then it used to brake shafts so we fitted granny back end
may be constanly going round on a oval track is wat fuked um up
Old Jul 22, 2006 | 01:07 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Im sure, even tho its not ideal, a lot of people do Sierra ones without even removing it?
Deffo better to remove it tho.
Brom- What model Mk3 granada back end you need, or are they all the same?
7.5in cossie style diff yeah?
I take it you need the whole lot, beam, arms, diff, driveshafts, brakes, the whole lot?
Old Jul 22, 2006 | 01:21 PM
CozzyBrom's Avatar
CozzyBrom
yes depending on wat ratios you want
there 3.36
3.62
3.64
3.77
3.89
mixture of 7 and 7.5s there
need beam hubs shafts n diff
Old Jul 22, 2006 | 01:22 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
dojj, graceland - arse
at least i know what to do now lol
cheers
Old Jul 22, 2006 | 01:28 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
there 3.36
3.62
3.64
3.77
3.89
But i guess u need the 7.5 as the 7 will be no stonger than the stock sierra shite will it?
3.36 is granada auto isnt it? 7.5in?
Old Jul 22, 2006 | 07:18 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
so do i need to undo the ferkin great 30mm nut to get the drum off?
once drum is off undo 13mm bolts and its off?
Old Jul 22, 2006 | 08:02 PM
dojj's Avatar
dojj
nononononononono
jack it up
remove the wheel
remove the drum
remove the shoes (all in one go once the little pin things are out you can just slide the whole lot over the top of the hub)
turn the hub so that you can get the holes lined up with the bolts
put a short 13mm 1/2 socket over the bolt you want to undo
stick and extension bar through the hole
undo the bolt (it migth be a tad tight)
turn the hub, repeat the proccess for the other 3 bolts
grab hold of the hub flange itself (the one with the holes in it and the studs for the wheel nuts poking out of it) and YANK!!!!
the whole hub carrier assembly should now be free
get underneath the car and YANK! the driveshaft itself
this should release the bit that goes into the diff without putting extra strain on the cv on the hub side of things
the whole shaft can now be with drawn through the wishbone
hth
Old Jul 22, 2006 | 11:29 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cheers mate, that explains it lol
Old Jul 23, 2006 | 02:50 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
as of 11am the diff is now on the garage floor, was a peice of piss when you know how!!
cheers to dojj and gracey!!!
ps didnt even need to remove the brake shoes, the hub pulls out no probs
Old Jul 23, 2006 | 03:06 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Told you it was easy you big girl
Old Jul 25, 2006 | 09:34 AM
dojj's Avatar
dojj
pics when it's all one big globule of moten metal then please
Old Jul 25, 2006 | 10:05 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
hopefully will get some mate.
i de-greased it last night, its got written on it 3.92, is that good for making the wheels spin lol??
all this ratio talk confuses the hell outta me
Old Jul 25, 2006 | 10:17 AM
dojj's Avatar
dojj
thats the shortest ratio they do really
you should have either 13 or 14 teeth on the pinion gear and either 46 or 47 on the crownwheel (it's been a while since i did all this stuff)
you should also find that it's going to be the more common 7.5inch diff in the back of the twinky rather than the 7 inch diff you might have been expecting (for some reason the twinky cars are 90% fitted with the 7.5 inch diff)
I've got the other end of the scale in my twinky, as in i've got a 3.14:1, coupled with the 0.75:1 overdrive as fitted to the granny cossie auto box, i should see plenty of mpg crusing down the motorways
Old Jul 25, 2006 | 10:25 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
so the lower the ration, the longer the gearing??
or is it the other way around??
cheers mate.
oh ps, did you got to the cops about your neighbours?
Old Jul 25, 2006 | 07:51 PM
dojj's Avatar
dojj
the higher the first number, the longer the ratio-n
with your 3.92:1 the prop will turn 3.92 times in order to turn the crownwheel once
with my 3.14:1 diff, the prop only needs to turn 3.14 times in order to turn the crownwheel once
there are lots of people who say you would need more power to turn the longer diff, but, as witnessed in the fsoc rr day in ff, one i had the lowest powered twinky on the day but, at ford fair last year, i absolutly blitzed the guys with more powerfull cars around the track (several times in fact because i kept going off at one particular corner ) because it's all a question of how you make the power and how you use it
Aug 29, 2015 08:16 PM
mattman1234
15
Aug 14, 2015 10:05 PM
track.focus'd
Aug 12, 2015 05:53 PM
xr4x4rs
Aug 6, 2015 09:03 PM
Bosch
Aug 4, 2015 05:14 PM
