16V 2L XE into MK1 XR2
As title has anyone done this before or know anyone who has done it?
Need some info on Bellhousing adaptor plates, Flywheel / clutch, engine mounts ect
Originally Posted by smitsturbo
i have seen it done before but f@*k knows how it was done? hope that helps
Just fancy something a bit different
Fucking superstar........
I know they make bellhousings for the T5 and type 9 box. Surely they could make one for the BC box. BUT, why not just stick a 2.0 16v zetec in it? Same result, less hassle
Originally Posted by rstoughy
Rab,
It might come to that if i cant get the info i require![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
Chris has an 1800 zetec on weber alpha throttle bodies. And it's the fucking nuts mate!
Guest
Posts: n/a
Originally Posted by Rab
I know they make bellhousings for the T5 and type 9 box. Surely they could make one for the BC box. BUT, why not just stick a 2.0 16v zetec in it? Same result, less hassle ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
What about the I4 from an RS2k? same standard power and ford
itd be easier to use a vuaxhall gearbox and get custom shafts made id have thought, cheaper too. you could get the 6spd vaux box with the LSD in there no bother!
then its just engine mount which wont be to hard if youre handy with fabrication.
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
And the RS2000 I4 weighs about 7 tonnes..... It's made from cast granite or something
actually! the 6spd doesnt have an lsd, its the 5spd that does! my mistake ![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Originally Posted by COMEDY DAN
Some people have some crazy Ideas
Cheers for all the replys so far folks
Regarding the gearbox issue, i would prefer to keep the 4 speed box and fit an LSD into that if at all possible.
And the reason behind using the XE is
1: i can pick one up really cheap
2: Cheap, reliable power in near standard form
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
what are they as standard 150bhp?
a zetec with a few choice mods should see near that with alot less trouble fitting, probably cheaper buying in the first place and will still be quick enough, lets remember a mk1 xr2 only weight what, 900kg?
wowk
30-03-2021 07:49 PM
