when reffiting a cossie head.....
should the exhaust manifold be put back on before hand, also any aother things that should be fitted that later would be a bitch to get at?
Thanx Sean.
Thanx Sean.
Originally Posted by DAN P
when i did the head gasket on mine i put head on with inlet on and zorst manifiold and turbo
cut the top off 2 of the old head bolts, then cut a slot in the top of them so you can get a flat blade screwdriver into them, then screw them into the bolt holes at opposite corners of the block. Now you can drop your fully assembled head stright on, no worrying if the gasket/holes etc are all inline screw a few new head bolts gently down, then you can unscrew the old bolts using a flatblade screwdriver- dead easy, much better than fucking about trying to put inlets/exhausts/turbos on in he car
No1 Blower.
I have done this and it worked well lining up the headgasket.
Russ Payne
25-09-2015 08:29 PM
