How much bhp will an 044 pump support?
18-07-2006, 07:30 AM
As title really. When will a single 044 run out of flow capacity.
If you want to go fancy calculations, assume a BSFC of approx 0.5.
Are they good for 500bhp?
18-07-2006, 07:54 AM
Did Someone Mention TUV
Yes they will easily flow enough for 500bhp providing the correct voltage is seen at the pump
18-07-2006, 07:58 AM
Quote:
...and that the fuel lines are up to the job.
18-07-2006, 09:37 AM
I think most decent tuners run two of these in parallel when you're running say 5.5-6 bar fuel pressure (~2 bar boost)..
18-07-2006, 10:52 AM
i just got 2 044's for my escos racer 540hp. even if one flows enough i still have an insurance if one goes bad
Have them from bosch-man on here, top bloke and top service !!!
michael
18-07-2006, 12:43 PM
..cheers mate.
Yes one will flow 600plus bhp i dont think its ever been max tested!
Obviously above 500bhp you will need bigger fuel lines.
18-07-2006, 01:14 PM
Baby Cheesus
is it worth having a std pump fromt he tank to a swirl pot, and then the 044 from the swirl pot to engine?
thats what i was gonna do
or will it be fine to just use the 044 from fuel tank to engine?
im gonna be using an ally fuel cell in the boot too.
18-07-2006, 05:09 PM
i run one 044 pump with no probs...
standard lines too
timsrs
13-11-2018 11:48 AM
Marv888
26-09-2015 03:44 PM
IainRS1700T
25-09-2015 06:44 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
