RS2000 in a mk4 escort?
Hi there peeps, me and a friend will shortly be putting a mk5 escort RS2000 engine into a mk4 escort, has anyone got any info or pictures on this convertion.
All bits of info no mater how big or small are useful (pics as well). Thanks for looking.
we are on doing an rs2000 into a d reg cabie,u will need to make up a new engine mount bracketon the drivers side.
are u using the rs gearbox as well???????
Ive heard that the bonnet wont close without some type of bulge or vent because of the timing chain cover. bit more info before you dent the bonnet!!
Resident Wrestling Legend
the engine won't physically fit under the bonet because it's too wide at the top
the easiest way to find out what you need to bend is to get hold of a sierra dohc rocker cover, find out how tall the engine is and then put it into place
you'll see that the exhaust cam sprocket bit of the cover will foul the bonnet so you need to either cut a hole in it or bent it out by about an inch
there is a guy who's done it in the xroc so that might be a starting piint
Originally Posted by RWD_cossie_wil
I have a complete Mk5 RS2k engine for sale cheap as chips if you like?
DEYTUKURJERBS
Wasnt there a green Mk2 Orion from Germany in FastFord a few yrs back with an RS2000 lump in it?
Had standard bonnet and seemingly no major mods to make it fit.
chris m1
07-09-2015 08:02 PM
