Engine removal time!
Old Jul 15, 2006 | 10:04 PM
Rippers's Avatar
Rippers
Monte Geek
Default Engine removal time!
Ok I'm doing an engine swap and i'm at this stage
Whats the best/easiest way to get the engine and gearbox out through the top? bottom?
Whats the best order of doing it aswell?
Cheers in advance for any tips/advise
Old Jul 15, 2006 | 10:07 PM
SPADGE's Avatar
SPADGE
Engine , box , suspension etc etc....all out the bottom complete with the subframe mate
Old Jul 15, 2006 | 10:09 PM
Franco's Avatar
Franco
SEE!!!!
This will be the easiest as you can then work on the parts swapping while not having to lean in a engine bay!!
You can hug me later!
Old Jul 15, 2006 | 10:13 PM
Eagle's Avatar
Eagle
Super Moderator
agreed ... where is dave with his picture
Old Jul 15, 2006 | 10:14 PM
Rippers's Avatar
Rippers
Monte Geek
OK through the bottom now can I have some detail of whats involved.
I'm guessing Strut top mounts, ARB, steering rack knuckle, crossmember
Will I have to remove the exhaust?
Hows the gearbox removed?
Old Jul 15, 2006 | 10:15 PM
Franco's Avatar
Franco
Oit sillybilly
You banned him remember!!
HOW DO YOU WIPE YOUR ARSE!!! (private joke!)
Old Jul 15, 2006 | 10:16 PM
Rippers's Avatar
Rippers
Monte Geek
Old Jul 15, 2006 | 10:17 PM
Franco's Avatar
Franco
Will I have to remove the exhaust? YES
Hows the gearbox removed? READ THE MANUAL MATE
I think its 3 bolts on the donut & four on top bolting to the tunnel........
Old Jul 15, 2006 | 10:18 PM
Rippers's Avatar
Rippers
Monte Geek
Will read the manual but I'm also after experienced tips/advise
Old Jul 15, 2006 | 10:19 PM
SPADGE's Avatar
SPADGE
I'll reply in a minute when i've had a think but i may be about to disagree with myself slightly
Rippers's Avatar
Rippers
Monte Geek
Cheers mate will appreciate it
Old Jul 15, 2006 | 10:41 PM
Eagle's Avatar
Eagle
Super Moderator
Oit sillybilly
the one from liverpool you numpty not the lordy lordy one
Old Jul 15, 2006 | 10:42 PM
Franco's Avatar
Franco
Oops!
Old Jul 15, 2006 | 10:53 PM
Eagle's Avatar
Eagle
Super Moderator
dave cos4x4
ask him .. he is an expert at it
Old Jul 15, 2006 | 11:01 PM
Fiecos Dan's Avatar
Fiecos Dan
i've done engine out of top once, and engine out of bottom 4 times on my fiecos,
And by far the engine, box, sub frame out of the bottom is alot easier and faster.
i had to remove zorst, steering uj, driveshafts, prop, TCA's, steering rod ends, and gear stick.
Old Jul 15, 2006 | 11:04 PM
Eagle's Avatar
Eagle
Super Moderator
can disconnect gearstick at the box tho if you can't get the roll pin out..
Old Jul 15, 2006 | 11:07 PM
Franco's Avatar
Franco
Easier to strip it off from inside the car then drop the box with the shaft still attached.
Less time under there the better i say!
Old Jul 15, 2006 | 11:09 PM
SPADGE's Avatar
SPADGE
Right ok i'll stick with what i said earlier as doing it any other way is just as much if not more grief!
You will need to remove the exhaust and the rear propshaft
Disconnect the speedo and clutch cables as well as un-plugging the reverse light switch
Remove the gear lever from within the car
Un-bolt the gearbox crossmember and front arb from the car.
Disconnect the front brake lines
Undo the top mounts for the front suspension
Support the engine with a hoist and undo the front crossmember bolts
Lower the lot to the ground.
The above is assuming you have already removed all the plumbing and wiring from the engine.
If i have forgotten anything which i no-doubt have i'll add it later
After it is all out use the hoist to lift the front of the car to enable you to drag the engine etc out from under. Please do it SAFELY though!!!
Old Jul 15, 2006 | 11:14 PM
Franco's Avatar
Franco
Knew i forgot something!
Ps Spadge i hope i'm not being charged storage
Old Jul 15, 2006 | 11:17 PM
SPADGE's Avatar
SPADGE
If you mean for that front diff i didn't know you had paid me!
No worries about storage if you have though as i binned it last Friday
Old Jul 15, 2006 | 11:21 PM
Franco's Avatar
Franco
Nah it deffo went through the second time mate!!!
Old Jul 15, 2006 | 11:22 PM
SPADGE's Avatar
SPADGE
Its here still so don't fret
Old Jul 15, 2006 | 11:27 PM
xr4x4rs's Avatar
xr4x4rs
as spadge mentioned is the easiest way
but ive done this, just get a trolley like this from homebase tesco or somewhere and chp the handle off
makes life so much easier as once that engine and box is on the floor is a pain t move from under the car
Old Jul 15, 2006 | 11:37 PM
Fiecos Dan's Avatar
Fiecos Dan
Old Jul 15, 2006 | 11:38 PM
SPADGE's Avatar
SPADGE
Good idea mate but i like doing things the hard way and using a bit more muscle
Another quick point for Paul you will need to do it outside of that garage or you are going to struggle like fook mate!
Old Jul 16, 2006 | 07:05 AM
Eagle's Avatar
Eagle
Super Moderator
i couldnt get the pin out of mine now matter how hard i twatted it
Old Jul 16, 2006 | 08:46 AM
Turbo lag's Avatar
Turbo lag
I took mine out form the top but it was a right pain
if you can lift the car high enough take it out from the bottom
Dave.
Old Jul 16, 2006 | 09:55 AM
Rippers's Avatar
Rippers
Monte Geek
Thanks for the advise peeps esp Spadge
Looks like today is going to be a proper mission
Old Jul 16, 2006 | 10:22 AM
maxest's Avatar
maxest
Good luck Paul! Has the original engine sold??
Old Jul 16, 2006 | 10:39 AM
DUDE_SWEET_FRST's Avatar
DUDE_SWEET_FRST
how did you aquire that trolly?
Old Jul 16, 2006 | 10:43 AM
dave cos4x4's Avatar
dave cos4x4
Paul,
make sure you drop it onto a trolley so you can wheel it out,makes things a lot easier.
same goes for putting it back in.
Old Jul 16, 2006 | 10:47 AM
xr4x4rs's Avatar
xr4x4rs
just borrowed it mate
need a van though
Old Jul 16, 2006 | 10:52 AM
Eagle's Avatar
Eagle
Super Moderator
thats the ones dave
Old Jul 16, 2006 | 10:54 AM
dave cos4x4
thats the ones dave
Old Jul 17, 2006 | 08:03 PM
Damo V's Avatar
Damo V
Out;
dropped subframe ect off using a cradle to hold block (head removed) from above, then lowered bottom end onto the deck lifted car slide it out
In;
Old Jul 18, 2006 | 07:48 AM
Eagle's Avatar
Eagle
Super Moderator
marks and sparks have some good trollys
they interconnect, 4 totally independant wheels, made from plastic and have a loading of 150 kg per unit would need 3 or 4 for an engine and gearbox tho....
JoeyBoyden
Jan 4, 2024 02:36 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
lockie
Jul 31, 2015 10:03 PM
