is this........
Old Jul 13, 2006 | 11:45 AM
gingeRS's Avatar
gingeRS
Default is this........
standard on all 4x4's?
the little oil return just at the top of the sump in this pic?
cheers to franco for the pic
can use that for my bailey breather?
ie one to underneath turbo, one to flame trap, vent to atmos and oil retun to there????
Old Jul 13, 2006 | 11:46 AM
WD Pro's Avatar
WD Pro
Mine has one
Old Jul 13, 2006 | 11:49 AM
gingeRS's Avatar
gingeRS
hang on a minute
is that where the flame traps breathes from, if so,
i'm trying to figure a way of fitting my breather without drilling the rocker cover and having to mod the sump
Old Jul 13, 2006 | 11:53 AM
WD Pro's Avatar
WD Pro
Yes - From std breather / flametrap.
I thought mine was leaking only to find the insulation on the oil pressure switch had cracked
Old Jul 13, 2006 | 12:12 PM
Alan s1's Avatar
Alan s1
Originally Posted by gingeRS
hang on a minute
I dont think you can fit the breather without the pipe coming off the rocker cover
Heres my rocker cover had it drilled and tapped my a company that does metal work ect
Old Jul 13, 2006 | 12:23 PM
dangerous - reyland's Avatar
dangerous - reyland
Ginge
breath it out of the hole by the engine mount threads Then do the same the other side
My sump has been welded to a high capacity one so it returns differently but am pretty sure you can return it to the one on the sump shown in your pic.
think (from memory ) that that pipe is "S" shaped & sits under the oil level
Old Jul 13, 2006 | 12:24 PM
dangerous - reyland
hold on Your sump is enlarged
can i see the return with a blank cap on it?
Old Jul 13, 2006 | 02:12 PM
gingeRS's Avatar
gingeRS
just to clear things up.....thats not my engine in the photos. although mine is a 200 block 4x4.
is it possible to remove the falme trap and all the gubbins without removing the inlet manifold?
Old Aug 3, 2006 | 09:04 AM
Franco's Avatar
Franco
How did you get on Ginge?
All sorted?
Old Aug 3, 2006 | 12:09 PM
gingeRS's Avatar
gingeRS
All sorted?
all done now
couldnt be arsed to remove the inlet, so removed the flame trap etc, and drilled the rocker cover.
managed to move the standard kidney box out a little, and get the breather pipe on that.
breathes from cam cover, kidney and ruturns under the turbo.
seems to work quite well.
Old Aug 3, 2006 | 12:17 PM
Franco's Avatar
Franco
Any pic's of your handy work Ginge?
Glad to hear its all sorted fella!
Old Aug 3, 2006 | 01:29 PM
gingeRS's Avatar
gingeRS
pics very soon
or come see it on the PF stand if you are coming to ford fair.
in the last few weeks i have:
Refurbished rocker cover
replaced boost and coolant hoses (with roose ones)
fitted mirror image breather kit.
repared power steering leak
changed oil and plugs
cleaned entire engine from top to bottom (steam cleaned underneath)
drained, cleaned and flushed coolant system
all done in time for ford fair
now all that is left is clean and polish, and its booked in @ SCC on sat for someone to beat the rear arches so the coilovers stop catching (i wont be watching )
Old Aug 3, 2006 | 01:32 PM
Franco's Avatar
Franco
Well i'm not........ So get the camera out!!
Old Aug 3, 2006 | 02:11 PM
gingeRS's Avatar
gingeRS
you will have to wait then chump
pics next week i guess
Old Aug 3, 2006 | 02:19 PM
Franco's Avatar
Franco
Good man.......
I'll show you mine if you show me yours!
Old Aug 3, 2006 | 03:23 PM
GUZZLER's Avatar
GUZZLER
looking foward to seeing the 'ol girl Ginge, one of the lads at work was asking after it the other day, i said it was in good hands
Old Aug 3, 2006 | 03:30 PM
Dave Henshall's Avatar
Dave Henshall
the pipe marked as no 2 is std on 4x4's, the hole at 1 is where the std breather goes and it return the oil to the sump via no 2.
so you remove the std breather completely, the fit one pipe to one port of your new bretaher on this side of the engine, the other port comes from the blank plug un the other side of the block the knock sensor has a small bolt folding the wire inplace as std) then your oil return goes to 2 back to the sump, the large vent on your brather then either vents to atmosphere or to a catch pot....
like so...
intruder
Mar 19, 2008 03:58 PM
Chip
45
Oct 17, 2007 01:25 PM
stundies
Ford Escort RS Cosworth
21
Jul 31, 2007 08:59 PM
