making a mp3 file smaller
Former Sponsor
bastard mong child....
you need editing software,...which i have got,...tell me the song, ill download it, make it smaller, then send via text...good enough for you dog breath
carl
she wants it for ring tone then??
carl
Try making it varable rate or just a lower bit rate or there is a program called mp3 splitter that lets you cut sections out if what you want is to make a ringtone. Can't remember where I got the program though now.
Irritating c........
Variable bit rate tracks are generally higher in file size, due to being able to reach peak bit rates, aswell as lower ones....
Two ways to make an mp3 filesize smaller;
1) shorten the track - cut it up. This is wise espescially if you are putting it on a phone as a ringtone - why put a 5min song on there when you only need 30secs for the ring tone?
2) lower the bit rate. EG: song is encoded at 192kbps - re-encode it at 112kbps... Lower bit rate = less "info" in the track = less info in the file = lower file size
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
TPM961
15-01-2018 10:50 AM
davidfox280585
Shows & Track Days
17-09-2015 10:09 AM
