cam cover
#47
Originally Posted by Franco
Well the 64 thousand dollar question Ginge! Believe me! ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
just trying not to get carried away and end up stripping a perfect engine like you mate
decisions must be made by lunch today
#53
Originally Posted by gingeRS
Bailey do their own fitting kit (£41), but I wouldn't use this set-up on anything other than a road car, as it breaths from flame trap and cam cover and then drains to the point that is heat-wrapped on my car. This is flawed for the reasons I have described above.
The Bailey breather in my picture has four outlets (two breathers (ports), one return and one drain).
is it the atmospheric port?
still HIGHLY gypo Mike!!
but to be fair, if you can't afford proper aeroquip fittings then what can you do.
God forbid though for your dizzyless conv.. you must surely have a proper blank in place... not just the std dizzy...
now THAT would be REALLY gypstonian!
![007](https://passionford.com/forum/images/smilies/bond.gif)
![Raz](https://passionford.com/forum/images/smilies/tongue.gif)
cap in ya ass mike to you
i have done 4 teardrops cam triggers
into a ecc4 cam cover
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
#55
Caraholic
#61
You get rid of the FLAME TRAP (red and black plastic thing listed as number 2 on the drawing below).
![](https://img.photobucket.com/albums/v125/apbms1/4wdschematicbreather.jpg)
But retain the kidney pot (1A).
drilling the cam cover, at 12pm, so must decide by then
do most people just shove the pipe into the top of the flame trap?
#66
Shove the pipe into the top of the old oil sep 1A (kidney) and forget about tapping the rocker cover!!
Works on a 480bhp engine, it'll work on us mere stage3 boys!![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
as i dont have a return to sump?
#68
Monte Geek
Mike could you not just lose the kidney and block off the original oil return and breathe from the block using one of these
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
#74
dammit
got the bits in the chuck now!
WHERE AM I GONNA FEED THE OIL RETURN TO???
is there anyone on here that hasnt drilled the rocker cover. but also doesnt have a fitting welded to their sump?
#77
If you want to do it without drilling the cam cover, Dave Hensell has detailed a solution on Franco's thread (see link below his signature). This requires both the flame trap AND kidney pot being removed though.
It also requires the fitting in Paul's post.....
cheers for the help and quick responses on this guys. cover hasnt been drilled .................yet
#78
Caraholic
#79
You can do what you like
. I personally would do it the way Harvey has in the pictures, hence why I never fucking noticed
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
#80
Any way you do it without draining to the sump is going to suffer this way, so absolutely no point what-so-ever in drilling the cam cover....
done.
i say this as i can bothered to remove the inlet manifold, and the kidney pot, and also i have a mirror image breather and draing to the point under the kidney pot would be a pain in the arse
cheers guys
drill is spinning
