dynomec very handy tool a must*updated with pics of locker
Old 10-07-2006, 01:46 PM
Stu.H
Stu.H's Avatar
I dont want them now!
Old 10-07-2006, 01:50 PM
AndyBlackFRST
AndyBlackFRST's Avatar
"As used by the AA"
Well maybe worth calling them out.. or having a polite word with one
Old 10-07-2006, 01:52 PM
Daveyboy
Daveyboy's Avatar
what do they retail at Scottyboy?
Old 10-07-2006, 01:54 PM
Stu.H
Stu.H's Avatar
completed ebay listing
HERE
Old 10-07-2006, 03:43 PM
timb551
timb551's Avatar
Good tool for theives
Old 10-07-2006, 06:23 PM
timb551
timb551's Avatar
lol, fair point
Old 10-07-2006, 06:32 PM
SteveB
SteveB's Avatar
I have never had a set of lockers that I cannot remove with a smaller impact socket and a fuck off hammer....
Even bought a car for the misses a few months ago and the guy at the garage gave me Ł100 back as he couldn't remove the lockers..... 30 minutes at home and she was all sorted
I would also like to add that I've never damaged a wheel either....
Steve
Old 10-07-2006, 06:43 PM
Fiecos Dan
Fiecos Dan's Avatar
Steve
Same Here
or used 12 sided socket, but normally fucks socket..
Old 10-07-2006, 07:16 PM
James
James's Avatar
We do this alot at work, atleast twice a week and tbh a hammer and chisel is usually best, air chisel is another good tool.
that tool is one used by the aa as we have it at work 9 times out of ten it does the job, it works like a impact driver, you bash the end and two curved spikes come out the bottom and embed into the nut then you can just spin it off.
hammer & socket is good aswell as mentioned, try hitting the nut face on with a punch to try and loosen rust on the threads, something else we've done is weld a big nut over the locker then undo that, depends on the types of wheels though.
Something else i've heard people do is remove other nuts then take the car for a short drive waiting for the nut to loosen, the trick is to stop before the wheel falls off so don't try it up the local dueller.
Old 11-07-2006, 02:30 PM
kevandalice
kevandalice's Avatar
Originally Posted by The Usual Suspect
heres the little fuckers anybody know the make of them it would be a great help gonna try one last time to identify them befor shelling out on the tool, the key is missing but is castle shaped, any help greatly apreciated
i had a set like that years ago i got them from halfords
Old 11-07-2006, 02:33 PM
DaveEscos
DaveEscos's Avatar
surely a gator grip will get that out Scotty?
Old 11-07-2006, 02:42 PM
Markb_s1
Markb_s1's Avatar
i've got some similar looking ones on my sierra.. i'll check them out later.
Old 11-07-2006, 06:54 PM
TrickyDicky
TrickyDicky's Avatar
those are the easiest of all to get off, if you get any 4 ovalled socket-like the type to remove them bolts, grind 3 of the oval keys off and dress up edges of last one, you have a wheel nut key that fits any of those type. i've got 1 pre ground down somewhere in my old toolbox.
hth
Tricky
Old 11-07-2006, 10:08 PM
James
James's Avatar
as he said above!
be off in no time, also i don't reckon that tool will work on that style of nut.
Ultimatly drill straight through the fucker, providing you do so on centre it'll be fine when through enough for the head to snap off take the wheel out and hopefully they'll be enough thread sticking out the back of the hub to turn withyour fingers.
Old 12-07-2006, 09:34 AM
S3an
S3an's Avatar
use a 9/16 or a 14mm socket just tap it on and they will fly off, done my mates car last week like that. all 4 were off in 1 minute.
Old 12-07-2006, 06:49 PM
James
James's Avatar
Pretty much yeah, good drill bit and something to lube it up, wd40 for example. centre punch the centre of it then get the drill out,
Old 13-07-2006, 07:47 AM
Markb_s1
Markb_s1's Avatar
did you get this sorted Scott?
definitely looks the same as mine. I didn't take the number down like a muppet but if it looks right you're welcome to give it a go?
07-10-2015 12:56 PM
griffo69
04-10-2015 11:58 AM
locum8
01-10-2015 01:50 PM
Quick Reply: dynomec very handy tool a must*updated with pics of locker
