Building a car from a new shell
1 Post
If a car is being built from a new motorsport shell, will it HAVE TO come on the roasd as a Q plate or is there any way around it
If enough parts are brand new with reciepts then it can have an age related plate so you could own a 56 reg cossie There are points awarded for certain parts, and I believe one major item such as the engine can be old. Martin-Reyland has done this I believe aswell as others on here with x reg and 02 reg cossies. Try a search
1 Post
It will be a focus cossie, so engine and stuff is second hand obviously, the rest of the parts are second hand focus rs like wheels, hatch, bumpers.
Check Martin's build as I think about page 10 it says that you need to earn points and if other a certain number it is allowed an age related plate
There is also a link to a site which explains it all.
Is he transfering many parts from one car ????
IE a saph into the focus shell ????
If he's using many major parts from 1 car you can have that reg transfered to the new shell i believe.
If you use the Cosworth parts in a new Focus shell I'd say you will get a Q (if these are still in use?)
The rules say the new shell should be of the same spec and a Focus and a Sapphire are obviously different, and the points scheme comes into play when you are building/rebuilding a car using parts from just one donor.
Using all new parts would be simple - you would get an 06/56 plate (depending when you reg it), but without a single donor you have no age to get a reg number related to.
Instead of a getting a new shell, it may be worth buying a write-off and rebuilding that with the Cosworth parts at the same time as the repair. In my opinion you will rarely get your money back on a modified car, so why worry about it being a write-off if you know the repair is done properly - and avoid the registration hassles.
Super Moderator
OK your going to buy a new shell which is fine you will have an invoice to proove this,apsrt from the shell you will ned all the oter parts to fit the shell up I gass,varous rubbers,plastics,carpets,sterring components ECT ECT so you will be needing to buy a donor car probably one which has been damaged,you then re shell the car and use the ID,This is pefectly legal to do,you then have a proper reg number and no hassle with Q plating which will invlove a SVA test,which you dont really want to be doing
Super Moderator
Originally Posted by jaycos
so pete its like building a kit car then ucan retain the vin and plate off the scraper cool
and by the way do not weld the donor chasis number into the floor,just stick it down as that again prooves you have not messed with the floor
JoeyBoyden
04-01-2024 02:36 PM
rog
04-09-2015 12:10 PM
