Show me your modified front bumpers!!! *PICS P2*!!!
Basically after a chat with Karl, I need to get some better airflow into the engine bay before I fit the GRS.
Anyone got one already modded they are selling, or can advise on how to get mine modded?
Pics please
Pics please
gaz have u got any more info/pics
getting it cut is no problem, its how to make it look good later
its a 90 spec bumper, maybe Id be better getting an 80 spec on, and chopping that as they fetch far less, and sell my 90 spec.
bud - already checked karls site, was talking to him earlier about it.
Originally Posted by Stu.H
do you have any step by steps?
twins, just off to look at your resto thread now
1) First cuts were made to the centre "bar" that the number plate screwed to. Just dut this as straight as poss trying to keep a good line to make the "mouth" square....
2) I mapped out and cut two 3mm MDF "plates" to the shape of the now cut pieces, dug out some of the foamy bumper filling stuff, and adherred them to the cut bits with body filler n' fibre glass stuff. Lots of sanding later it was nice n smooth
3) More body filler, muchos sanding and the over all shape came out, then simply sprayed with filler primer and wet n dry'd it ready for painting
They do look wank cut out. I got a big wanky one at the moment, but cooling is spot on. Needs tidying up, but will still put a std one on for cooler months.
Twins - what kind of filler did you use to stick to the foam?
Phase 1 complete...
Now, how much to cut out of actual bumper, and where to relocate the number plate, the fit twin kenlowes and grs in a bit
also, ive been told to put the kenlowes on the radiator, and the intercooler bare in front.
although looking at it now, i cant see there being the clearance for the fans?
the previous owner of this cooler had it set with fans on front of intercooler blowing thru to radiator?
whats everyones thoughts?
Thanks in advance!
Thanks in advance!
bit of a silly question mate but how many bolts were holding your bumper on? tried taking mine of today , the front 2 bolts are off and the the srews on the wing but its on solid still and i cant find whats holding it on
4 bolts 2 screws
1 bolt either side of radiator under headlights
1 bolt in either inner wing/front panel (behind water bottle on pass side.)
1 screw on each arch.
im taking delivery on a GRS cooler soon too
All finished (just need to touch up round by where the cut was made, number plate is already mounted at very bottom of bumper).
Hope you like, I know not as neat as some people have done, but rather than pay someone £200+ I spent a day at it myself, and feel I have done OK.
Thanks for all the people that advised, also those with opinions, it was MUCH appreciated
Anyway...
Anyway...
