Weber PF01 TPS
All ive got:
'At engage of track voltage will jump to 4.5volts, as opened further will gradually decrease until max of about 0.5 to 0.6 volts.
the variable resistance measured between the supply and signal terminals will be infifnity when throttle is closed, around 40 to 150 ohms when throttle is just open, and increase to around 300 to 600 ohms as throttle is opened.'
Hope that helps.
Hope that helps.
everything you need at http://www.mmcompsys.com/ ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
DixieTheKid
11
06-06-2020 11:20 AM
