lamba sensor problems
Old Jun 30, 2006 | 08:17 AM
Badman38's Avatar
Badman38
Default lamba sensor problems
Can any one tell me the symptoms when the lamba sensor goes wrong? I am running closed loop on a s8 ecu and the car was running rich with an erratic idle, i have checked things like map sensors, ignition amps, how can I check the lamba sensor functioning? , there are four wires on the lamba sensor the grey wire was wasn’t connected but when I connected this wire thinking that it maybe positive but the car cut out on doing this… is this the right wiring sequence. Black = ecu sensor wire number two on the port ecu plug. Two white one = positive the other white plus grey = negative.
Thanks
Sean
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
tib2220
Sep 14, 2015 12:33 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
