help running problem :-(
Old Jun 29, 2006 | 01:04 PM
steve rs's Avatar
steve rs
Default help running problem :-(
my car seems to have developed a problem when driving at low revs it the rev counter drops to 0 and there is nothing as if someone has turned the car off then if i press the accelerator seems to stutter then rev again back to normal. this is not happening all the time more when cold. but seems to be getting worse. car is running fine but just seems to be cutting out at low revs has anyone had this problem before or know what it could be?? thanks
Old Jun 29, 2006 | 04:44 PM
steve rs's Avatar
steve rs
bttt any help much appreciated
Old Jun 30, 2006 | 06:59 AM
Lou Lou.'s Avatar
Lou Lou.
Old Jun 30, 2006 | 08:21 AM
Stu @ M Developments's Avatar
PassionFords Creator
Ignition Amplifier starting to fail is a possibility.
Old Jun 30, 2006 | 08:23 AM
Graceland's Avatar
Graceland
Team HOTHOT!
Slowpoke had similar simptoms to you - then his cut out,
Stu traced the problem to the crank sensor plug - the pins had vibrated away causing this problem. Worth checking the crank sensor tho too
Old Jun 30, 2006 | 08:26 AM
Indeed he did.
Old Jun 30, 2006 | 08:27 AM
Graceland's Avatar
Graceland
Team HOTHOT!
I know all too well Stu - 5 hours and over 100 miles
Old Jun 30, 2006 | 08:30 AM
If it makes you feel any better, i didnt charge him either.
Old Jun 30, 2006 | 10:09 AM
Graceland's Avatar
Graceland
Team HOTHOT!
Top service there Stu
Only thing I asked of Matt was a bottle of pop and a couple of brews
Old Jun 30, 2006 | 11:27 AM
steve rs's Avatar
steve rs
i have already changed the crank position sensor and it made no difference. i will try the ignition amplifier tonight is that the bit that bolts on the wing near the battery? thanks
Old Jun 30, 2006 | 11:31 AM
Graceland's Avatar
Graceland
Team HOTHOT!
steve - check the pins in the wiring plugs for all sensors aswell
Old Jul 4, 2006 | 04:13 PM
steve rs's Avatar
steve rs
i have changed the ignition amplifier and it is still the same and i have checked that all the plugs are on correctly
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
