Central Heating help
Old Jun 28, 2006 | 08:26 PM
Kev.H's Avatar
Kev.H
Default Central Heating help
Ok my boiler blew a board so I have swapped it and I now have hot water again but the pressure gauge is low (I guess caused by using the stsyem when busted) so how do I get the gauge up do I need to bleed the rads if so how
Boiler is a Potterton Puma 80e Combi
Old Jun 28, 2006 | 08:27 PM
rsnissan's Avatar
rsnissan
you need to charge the system again should be some knobs below the boiler to do this
Old Jun 28, 2006 | 08:31 PM
Kev.H's Avatar
Kev.H
i got a red and blue kinda taps things on 2 pipes could these be them
Old Jun 28, 2006 | 08:32 PM
nellyscossy's Avatar
nellyscossy
you need to find your filling loop(usually a flexy braided hose with a small tap or two on it)
then fill the system till the gauge reads 1.5
the filling loop will be connected between a 22mm pipe and a 15mm pipe
and it should be close to the boiler usually directly underneath but depends who fitted it and when youve done that make sure the tap(s)you have opened are closed again properly
Old Jun 28, 2006 | 08:33 PM
Kev.H's Avatar
Kev.H
i just found a red nob which lets pressure out
the two tap type things it is next
if I dont reply send ambulance
Old Jun 28, 2006 | 08:36 PM
shane's Avatar
shane
U want the inlet,the two uve described sounds like iso valves on ur outlets!
Old Jun 28, 2006 | 08:40 PM
Kev.H's Avatar
Kev.H
red and blue taps dont move
but I found a black one which sounded like it put in water and Im now boosting on 1.5bar
The water when the pressure is low seem to pulse hot and then colder could this be caused by the lack or pressure
thanks people top advice
Old Jun 28, 2006 | 08:41 PM
nellyscossy
the filling loop i described wont be connected to the actual boiler it should be just underneath on the connecting pipework usually about 10" or so below
Old Jun 28, 2006 | 08:44 PM
Kev.H's Avatar
Kev.H
yep thats about where it was 1.5bar is ok yes ? dont wanna surge my boiler
Old Jun 28, 2006 | 08:45 PM
nellyscossy
if your hot water out the tap plays up when the pressure is low then that may be the cause BUT if it carries on doing it at normal pressure ( say 1.5 bar) then youve got a problem......you better call the A TEAM...lol
Old Jun 28, 2006 | 08:46 PM
nellyscossy
1.5 when the boiler is cold is fine , should rise to 2 when youve had the heating on for a bit
Mark V8's Avatar
Mark V8
Throw the combi in a skip and buy a proper boiler with a hot water tank Plumbers don't tend to have combi boilers and that has to be a good reason not to bother.
Mark
Old Jun 28, 2006 | 08:49 PM
Kev.H's Avatar
Kev.H
thanks again will test shower again morrow hopefully was caused by the very low pressure
its run perfect for 6 years this boiler now im selling the property it goes tits
nico12
Dec 31, 2015 04:42 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
cossie09
Sep 10, 2015 06:56 PM
