Special ford tool suppliers?
Team HOTHOT!
I need to get a special tool for removing the input shaft locking collar on the MT75 gearbox (2wd or 4x4, both the same nut) - its some large socket that is very deep, does anyone know where I can get one of these tools, apart from Ford who would charge a fortune
Team HOTHOT!
Box spanner won't be good Gareth - the socket needs to be 12 sided and not 6 ![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
I've searched on all the usual tool supplier webbys and can't find anything![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
Maybe, If i can get a normal 12 sided socket, get jiggy with the angle grinder, weld in some box section, and then weld the top onto that, I'll have a nice deep socket
The next question is, what size is the socket I need
It's about Ł50 from Ford IIRC.
http://www.etis.ford.com
Click services then special tool catalogue at the top.
Failing that, make one with a socket and a peice of scafolding tube!!
Team HOTHOT!
Daz - just been reading on Interford, its a 46mm socket, but you can remove the nut by tapping it round a bit then spinning it off by hand - should save me some money ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
Then the rest of the gearbox should just pop apart once the bolts holding the case together are undone, with a bit of luck
Team HOTHOT!
Dojj - just done a search on Interford - found all the pics of Tapp's tool (oooeer
With regards to removing the front case, which 5th gear bolt do you remove, and which one do you leave in?
Resident Wrestling Legend
there are 2 bolts that hold the reverse gear in place
one either side of the box halfs (front and rear)
let me go and get some pics of what i mean
if you undo both then it's a bit tricky to get it all back together again
and whatever you do DON'T take the gear selector locater thing apart, it's a right pain in the butt to get back together again, a mistake i learnt to regret
Team HOTHOT!
Ahh yes, i'm with you, If i leave it on the tail section, then the case should come off with no cogs inside it
job for tomorrow
job for tomorrow
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
borboyous
22-08-2015 11:17 AM
