FAO Dojj, Bernie, MOB or other gearbox bods......
Team HOTHOT!
How easy is it to remove the front case on the MT75 gearbox?
I need to swap the front case on my 2wd MT75 gearbox for the front case off my 4x4 mt75 gearbox.
If its easy enough, i'll do it myself, If not, i'll spend some money at a transmission service place
cheers
cheers
Resident Wrestling Legend
you just need to find a socket for the input shaft surronding ring thing (don't know what it's called though)
once thats sorted you just undo the bolts around the outside of the centre line, one that holds the reverse gear idler cog and then just prise them apart
BUT
you will need to remove the cogs to swap over the input shaft so it's not as simple as you might think
i'm sure someone will come along with the corect sized socket you need, but when i enquired about getting one i was quoted Ł300 so i used a screwdriver as a drift and a hammer to knock it round via the clutch lever hole in the bellhousing
BUT
chowfornow
14
05-01-2019 09:01 PM
