Any Mercedes gurus here???????PLEASE HELP!
My 320CLK wont rev past 4k ...on part throttle it seems too...on full throttle it just feels like its hitting a limiter a major misfire the engine rocks from side to side as it hits 4k its tries to go further but cant.On reving from idle it hesitates then revs....below 4k it drive very well.
I have done a full ECU reset but still does it.
Its been on a fault finder but everything is clear.
No engine management light is on either
I noticed the air filter was dirty so i took it out but still the same??can plugs cause this?..How about the MAF??? but no managment light on??
Hi,
was the fault finder original mercedes??
They can check the amount of air the engine is taking.
If this to low the air mass sensor is broke.
And there is no managment light with this failure
Hope this helps
Johan
Hope this helps
Johan
D1on
05-09-2015 09:11 AM
bassboy
08-08-2015 10:21 AM
