what injectors for 450cv
i am thinking for the future, and i would like to know what injectors i need to obtain 450cv
i know that there is the grey, but i suppose that siemens which are newer than the grey, are better
but, there is a different siemens deka :
- 55 599cc
- 72 788cc
- 83 903cc
so, if the price is the same, what will be the best for 450cv
- 55 599cc
- 72 788cc
- 83 903cc
Unless you go and see Stu @ MSD you may struggle to get a chip for the siemens injectors.
Mind you at that level of power i wouldn't recommend an off the shelf chip anyway.
In order of preference i would either
1) Go with the Siemens injectors if you have an aftermarket ECU.
2) Go with the siemens injectors and speak to Stu about chip / live map.
3) Go with greys and a chip.
If you go with the siemens 55s for 450bhp they will be pretty much maxed out at about 95% duty cycle running 3.5 bar fuel pressure.
I would go with the 72s to give you a bit of flexability and room for future upgrades.
thanks
yes, i understand.
But, i am searching somebody to map my car in france, so, i suppose that i will find somebody able to map the siemens
For this power, i don't want a off the shelf chip
yes, i understand.
Originally Posted by sygjim
so, if i can't have closed loop, the best choice will be grey or 72lb siemens
Just one question regarding these big siemens injectors. Can they be used in a catalysator car that should have low emissions, Escort Cosworth for example? Is it possible to get good enough emissions with them? I'm just asking since I just bought 788cc siemens deka injectors and had msd 1000cc injectors and they were quite crap (huge differences) and I couldn't get emissions correct with them. I just yesterday installed the siemens injectors and it seems that the idle is much better with them so I'll try my emissions again later this week. It does idle wery well with AFR14.7, it will idle even with AFR16 if needed.
yes, but i can't go to blackpool for the live mapping
so, i suppose that french tuner can't map the Stu closed loop
PassionFords Creator
If you have the car mapped locally and send the (Unencrypted) software to me, then for a fee the software can be made closed loop no problem at all provided the base used is compatible. The Pectel serial datastream can also be added for another fee. There are of course provisions to this offer as no tuner will warranty their work after someone else has adjusted the run program, and we of course will not warranty any run maps that we were not paid to map.
We will of course not alter the run maps made by your tuner, but should anything ever go wrong that is mapping related, naturally the blame will become a tennis ball. lol
It is always more complex than most people initially consider.
Originally Posted by yrkesman
Just one question regarding these big siemens injectors. Can they be used in a catalysator car that should have low emissions, Escort Cosworth for example? Is it possible to get good enough emissions with them? I'm just asking since I just bought 788cc siemens deka injectors and had MSD 1000cc injectors and they were quite crap (huge differences) and I couldn't get emissions correct with them. I just yesterday installed the siemens injectors and it seems that the idle is much better with them so I'll try my emissions again later this week. It does idle wery well with AFR14.7, it will idle even with AFR16 if needed.
I muist add, it sould like you have swopped injectors and kept the old software? this is a REALLY bad thing to do mate, please take care.
idle: HC less than 100, CO less than 0.5%
+2000rpm: HC less than 100, CO less than 0.3%, lambda 1(+-0.03).
The emissions in Finland are:
mk3ste
17-10-2021 10:09 AM
DixieTheKid
11
06-06-2020 11:20 AM
