Fooking BT :mad:
Following on from my thread a week or so ago discussing usage limits. I have just spoken to BT about it.
My Broadband account is subject to a 40gb usage limit. They claim for last month, I used 57.08gb and if my usage continues to exceed the 40gb limit, they will charge me £1 per gb that I go over.
On Smit's advice (thanks Smit) I now use Netlimiter Pro to monitor my usage, but for last month, it shows 38gb (approx), which is 20gb less than BT are claiming.
![](https://img.photobucket.com/albums/v16/christianbeccy/Netlimiter1.gif)
![](https://img.photobucket.com/albums/v16/christianbeccy/Netlimiter2.gif)
Since the May stats, I have restricted the Upload speed to 3kb!!
BT tell me that there is no way is my software right and that their system is definately right. I have been faithful to BT, but I reckon they are gonna lose our BB account very soon.
The other question is, when they upgraded me from 2 meg to 8 meg, would they have renewed my commitment, binding me for 12 months again?
The 8 meg upgrade turns out to only be 5.5 meg in my area, due to technicalities within the exchange. However, I have measured it using more than one site and it comes back, at best, as 4 meg (on a good day).
Pretty much every ADSL provider puts in these usage limits, however Plus.net dont charge when you go over, they just slow the connection down..
(Plus usage is only counted during peak hours)
I believe some providers have experienced problems with their "counting" software and very often read over; eg. Plus.net has recently informed all its customers that has been the case...
Cheers.
Cheers.
BT offer a service where you can log in and check your usage. We have it.
Going offtrack slightly I'm positive ISP's dont just messure the amount of data transfered but the type of data / websites visited etc.
If your downloading dodgey films etc im sure they know. If your looking at some bird doing unholy things with a pig and a strap-on they know about it!
spying fuckers.
spying fuckers.
A guy I work with had a similar problem but with NTL. What happened was he had set up a proxy server and people where using it to upload and this was going against his allowed limit. He had uploaded 370gb in one month according to NTL.
So, all these additional things like people raiding my internet connection, what should I watch for??
I notice that my Wireless feature on my router is currently enabled, when I look on the system settings. I can't imagine anyone is stealing from me via wireless though, I don't think I have anyone close by who is under pensionable age!!
Anyone know how to turn the wireless off? Its a Belkin Wireless-G Router....
PlusNET (to use an example) and their Ellacoyas (and any other ISPs that use that kind of equipment) can no doubt differentiate between the TYPE of traffic, but to do full deep-level packet-inspection to determine the content of each packet transferred would take LOTS of ridiculously powerful equipment and would slow connections down quite considerably.
to access your router you usually type 192.168.0.1 in the address bar. if this doesn't work double click the little network connection screen in the taskbar click support and the number after default gateway is what you need to type into the address bar to access your router
if your wireless is not protected then anyone in range can use your connection
Originally Posted by Tangodeltasierra3
Go with AOL - totally unlimited 24hrs a day if u like.
I've been with Freeserve/Wanadoo now for a few years and can't fault them
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Sidewinder G2's for example (http://www.securecomputing.com/index.cfm?skey=1026) can inspect traffic in/out as well and a few of these could easily inspect ISP level traffic right to application level - just take a look at the throughput rates...
Sidewinder G2 Security Appliance performance
3+ Gbps stateful inspection throughput
Unparalleled 2.2 Gbps of application layer throughput
15,000 connections accepted per second
170,000+ new mail messages per hour
Up to 1,000,000+ total simultaneous connections
"Tunable" firewall balances performance against security requirements
Visitor from the Darkside
Stupid as it sounds, I cannot find any option in there to disable the Wireless.
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
G
Got to plus.net can't go wrong with them, as above they inform when you go above the 'fair' usage and just cap your speed until another limit around 30Gb i think then slow the connection further unless you are around 100Gb per month!
Plus.net sounds like the way to go.
Regarding my Router. I want to disable the Wireless aspect altogether at the moment, but there doesn't appear to be a simple 'off' or 'disable' function anywhere!!![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
As Thorpey said what is the exact make and model?
bcracknell, the sort of equipment youre talking about is still nowhere near as powerfull as that being discussed.
theres a BIG DIFFERENCE EBTWEEN LOGGING GENERAL http TRAFFIC AND (oops caps...) actually examining every single packet in/out
Christian and Beccy
turn off broadcast ssid, that will limit the connections via wireless.
also under wireless security, turn on wep 128 and enter a 26 digit code
(number or letters), then save,
people wont be able to connect then
COSSIE LEE - Foooook me!! Whatever do you download??
Spiky, I have now found how to turn the Wireless off. I will try and set the security up properly before I resort to that though. It has a choice of 64bit or 128bit WEP, which should I use?
Is there any way of seeing who has/is connected to my router?
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
it should have an option, show wireless clients connected
if you got no wireless, you wanna hope it says none
Christian and Beccy
change the password for your wireless router.. some body in your street is playing piggy back on your connection
i got the bt adsl upgrade they said 4 meg at least
its still running at 2.5 at the mo ..
and got a bill on monday for £177.
cost of phone calls £19.69
service charges
£131.55
bt together option £30.63
broadband services £96.46
calling features £4.46
then added vat
rang up before caused fucking murder on the phone
it seems the bill is a 3 months in advance payment
thats how there working it out now
so they want me to pay up till the end of august ...
and the shonky new adsl modem still only pulls in 2.5 meg
I FEEL A CHANGE ISP COMING ON REAL SOON
service charges
then added vat
![Content](https://passionford.com/forum/images/smilies/content.gif)
![Bat](https://passionford.com/forum/images/smilies/pascontent.gif)
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
just got this email from bt
Dear Mr avid-fan
You may have seen in our latest adverts that BT Broadband is changing. Following the roll out of up to 8Mb download speeds¹, you’ll soon have the chance to take advantage of a new wireless BT Home Hub and open up a world of exciting possibilities. We’re calling your enhanced service BT Total Broadband. With BT Total Broadband, you could get:
• up to 8Mb download speeds – subject to availability
• free Broadband Talk Evening & Weekend UK2 Calls
• free Videocalls3
• 250 BT Openzone minutes every month4 for wireless internet access at ‘hotspots’ around the UK
• our best-ever online security packages
…all at no extra cost.
Plus – your usage guideline is increasing
We’re also increasing your usage guideline – the total amount of data you can send (upload) and receive (download) through your broadband connection each month.
- BT Broadband Option 3 usage guideline will increase from 20GB to 40GB.
- BT Broadband Option 4 usage guideline will increase from 40GB to 50GB.
A Total Broadband solution
It’s easy for you to get more from your internet with BT Total Broadband. You’ve all you need in one simple package – simple set up, wireless freedom, the latest internet content, great security – and automatic updates to help you make the most of new services as soon as they become available.
We’ll be in touch again soon to let you know how you can take advantage of these great new features.
Kind regards,
The BT Total Broadband Team
1 8Mb speed is subject to various factors including local availability, distance from exchange and line test. If your line won't support up to 8Mb, we'll offer the best speed available on your line. Conditions apply. A new 12-month contract will apply, starting from the date of your upgrade.
2 Means Local and National calls. Excludes non-geographic calls (0845, 0870), premium rate numbers, information services, calls to mobile and the Channel Islands. Other exclusions apply. Calls are charged at 3p a minute after one hour. Redial before one hour to avoid call charges. Subject to status. The quality of the reception on the phone line may not match that of a normal landline and may vary depending on internet traffic. Service restrictions apply. Certain call types are not guaranteed e.g. 999, 112 emergency calls. Service will fail if there is a power failure. Abuse policy applies. Touchtone telephone required.
3 BT Broadband Talk free Video Calls apply when both caller and recipient use a BT Videophone or BT Softphone with webcam. Requires BT Broadband Talk and VoIP-enabled router or BT Home Hub.
4 You will receive a voucher for 3000 minutes being 250 free minutes a month for 12 months. When you’ve used up all your inclusive minutes – or it’s after your first 12 months – you’ll need to buy a voucher or subscription to continue using the service. Inclusive minutes do not apply when roaming abroad. You need a wireless-enabled PC or Mac laptop, a personal digital assistant (PDA) or handheld games console (such as Nintendo DS).
Dear Mr avid-fan
• free Videocalls3
Kind regards,
Mine might only be on 2Mbps, but it's still unlimited-download, so I can pull down the maximum theoretical amount of about 632GB a month, if I could find enough space to store it!
Ben26
27-08-2015 08:56 PM
