Cosowrth track control arms with nut fitting on ball joint
Old 16-06-2006, 09:15 AM
Iain Mac
Iain Mac's Avatar
Default Cosowrth track control arms with nut fitting on ball joint
Are these for a 2wd?
My 4x4 ones use a pinch bolt
Old 16-06-2006, 09:16 AM
Micky The Finn
Former Sponsor
Micky The Finn's Avatar
3door ones only.
Old 16-06-2006, 09:21 AM
Iain Mac
Iain Mac's Avatar
So does that mean they are worth more (LOL!)
Bought them on ebay as being 4x4 parts but they have the wrong bottom joint. Don't suppose there's a great deal of point asking to send them back - the post was £8!
Old 16-06-2006, 09:22 AM
Micky The Finn
Former Sponsor
track control arms used dont seem to sell for much regardless of what they were off.
Old 16-06-2006, 09:38 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Unless you have the three-door hubs to go with them...
Old 16-06-2006, 09:40 AM
Micky The Finn
Former Sponsor
ive plenty here.
Old 16-06-2006, 09:41 AM
Mike Rainbird
Caraholic
With the extended knuckle?
This is a VERY worthwhile conversion for Sapphire 2wd owners .
Old 16-06-2006, 09:44 AM
Porkie
Porkie's Avatar
What does it do to car then Mike?
Old 16-06-2006, 10:05 AM
Mike Rainbird
Caraholic
Retains much more accurate geometry control - hence why it was designed for the 3-door homologation cars (for racing). It was ommitted from the Sapphires being seen as not required. This means that Sapphires have variable geometry control on the front suspension changing from positive to negative camber as the suspension moves up and down (when lowered) .
The three door with it's extended knuckle means that the TCA is at a steeper angle which remains pretty constant with suspension travel. The Sapphire one without the knuckle is at a much shallower angle as standard, but goes parrallel when lowered. This means that as the suspension compresses / unloads, the TCA pulls and pushes the hub for random geometry settings much like it does on the rear .
Old 16-06-2006, 10:43 AM
Micky The Finn
Former Sponsor
and dont you feel it when you drive a sapphire,they are like jellies on a plate.
155lee
14-08-2015 11:21 AM
Botts
13-08-2015 04:16 PM
RIB1122
12-08-2015 08:49 PM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: Cosowrth track control arms with nut fitting on ball joint
