Pedal Box assembly?
Old 10-08-2004, 10:53 PM
RichardPON
RichardPON's Avatar
Default Pedal Box assembly?
Got my bias pedal box (cheers Tim!), and at the risk of sounding stupid, I need to know how to set these up before installation.
Actually putting it in the car is done - what I need to know is how you set each cylinder up, and how you lock off the thread on the master cylinder rods?
Pedal box:
Brake bias:
Never done this before.................. Mark, yes I know we spoke on the phone, but it might be more easily explained with pics
Old 10-08-2004, 11:03 PM
andyescos
andyescos's Avatar
The thread goes to an adjustable bias knob via a cable( see Demon Thieves catalogue) so you can have more pressure to front or rear, if you get one that clicks its better, mine has 18 clicks, What do you mean by setting them up?
Andy
Old 10-08-2004, 11:07 PM
markk
markk's Avatar
lock nuts on th erods m8 , looks pretty much in line as for the cylinders m8
and thats fookin it !!!!
Old 10-08-2004, 11:10 PM
markk
markk's Avatar
oh and make sure your 'free play'into teh cylinders is the same when the pedal is in the 'brakes off ' position i.e usually screw the threaded bar of the master into the recievers the same amount before lock nuting them
Old 11-08-2004, 08:34 AM
RichardPON
RichardPON's Avatar
Andy,
I've got the bias adjuster with it.............
Mark,
Cheers mate - wasn't that I didn't trust ya, just wasn't 100% about it...... better to ask and all that!
Old 11-08-2004, 08:38 AM
i fixed my adjuster on the box and use a bias valve to adjust the bias to the rear now, as the pedal box is harder to move when drivin
Old 11-08-2004, 11:12 AM
RichardPON
RichardPON's Avatar
Not a bad idea Dingly...............
How did you secure the master cylinder rods to the bias bar, to stop them undoing?
One nut on each master cylinder rod?
Old 11-08-2004, 08:28 PM
RichardPON
RichardPON's Avatar
upski
Old 11-08-2004, 08:37 PM
markk
markk's Avatar
dingy,
if you need to further restrict the line pressure with pressure reducers then your brake setup is not specced properly - been there done that !!
Old 12-08-2004, 08:38 AM
RichardPON
RichardPON's Avatar
Mark - answer the damn question!
Old 12-08-2004, 08:48 AM
Really, works fine with the pedal box, the bias adjuster is to make it easier on the driving so you can also been there done that.
Old 12-08-2004, 05:17 PM
markk
markk's Avatar
Old 12-08-2004, 05:18 PM
markk
markk's Avatar
dingy,
yes really if you have a bias pedal box then why do you need a line pressure reducer ???
Old 12-08-2004, 05:21 PM
CozzyBrom
CozzyBrom's Avatar
pon plz tell me ya not using that mate
go hydrolic mate plz
Old 13-08-2004, 08:34 AM
Box is setup, but the weather changes so u need a little tweek, so would sooner do it with the bias of the line adjuster so the pedal feel stays the same
Its just for fine adjustment, and it does work, as for most rally boys
Old 13-08-2004, 08:57 AM
RichardPON
RichardPON's Avatar
Mark - fook off ya cheeky shit! I told ya, I'm certainly no mechanic
Brom - I haven't got the time or the money at the moment, so one thing at a time. You can work your wonders with the car when I get a chance.....
XR4
Ford XR Range
01-10-2015 12:46 PM
Steve Escos
01-10-2015 06:57 AM
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
Quick Reply: Pedal Box assembly?
