450BHP-How to and How Much?
Old 15-06-2006, 07:58 PM
_DAN_
Yoon
_DAN_'s Avatar
Default 450BHP-How to and How Much?
Right this is what i thought tell if i'm wrong,
200block
headwork
bd14's
lowcomp
GT30/T4
Old 15-06-2006, 08:01 PM
TIFF
Chasing Radders
TIFF's Avatar
Very roughly...............................Yes
Also
Intercooler
Exhaust
Greys or bigger
Dont NEED a 200 block
Live mapping
Breather system
Verniers
Clutch
Brakes
Head gasket...do it right will cost you £400
ect ect
Old 15-06-2006, 08:15 PM
aduz
aduz's Avatar
and hold on tight
Old 15-06-2006, 08:18 PM
Rhys
Rhys's Avatar
Wont be as cheap as you think. What ever you think add half of that on agian
Old 15-06-2006, 08:21 PM
aduz
aduz's Avatar
Rhys..what was the addy of that pool site we use to play on?
Old 15-06-2006, 08:22 PM
TIFF
Chasing Radders
TIFF's Avatar
www.gaypoolsharks.com
Old 15-06-2006, 08:23 PM
_DAN_
Yoon
_DAN_'s Avatar
www.ithinkimahardmanbecauseiplaypool.co.ck
Old 15-06-2006, 08:24 PM
aduz
aduz's Avatar
im sure it wasnt any of those
TIFF
Chasing Radders
TIFF's Avatar
Old 15-06-2006, 08:25 PM
Rhys
Rhys's Avatar
PMSL! Fook knows mate the link is on my laptop and i havent got a clue.
That might have the be fired up agian soon!
Old 15-06-2006, 08:27 PM
aduz
aduz's Avatar
anyway tiff you use to play on it
Old 15-06-2006, 08:28 PM
TIFF
Chasing Radders
TIFF's Avatar
Oh THAT pool site
www.toppoolsiteformanlymen.com
Old 15-06-2006, 08:29 PM
aduz
aduz's Avatar
TIFF
Chasing Radders
TIFF's Avatar
Old 15-06-2006, 08:30 PM
Rhys
Rhys's Avatar
Fpmsl at Tiff,
Thats right u used to play it Tiff, But you was so good and i was utter shite that i stopped using it and i became a loser of the highest order
Old 15-06-2006, 08:32 PM
aduz
aduz's Avatar
no when tiff was losing he suddenly had to go out
Old 15-06-2006, 08:33 PM
TIFF
Chasing Radders
TIFF's Avatar
Thats right mate
tregmatt
tregmatt's Avatar
it will cost a hell of alot
Old 15-06-2006, 08:36 PM
aduz
aduz's Avatar
www.poolcompsonline.com ..sorry to hijack your thread dude
Old 15-06-2006, 08:39 PM
Disabled Account
Disabled Account's Avatar
No it wont, Tiff said:
Originally Posted by Tiff
.............do it right will cost you £400
Old 15-06-2006, 08:52 PM
cossie350
cossie350's Avatar
Try adding a 0 and x2
Old 15-06-2006, 08:57 PM
TIFF
Chasing Radders
TIFF's Avatar
That was for a proper headgasket you muppet
Old 15-06-2006, 11:52 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Fuck, i was thinking 1 million dolla, and it even more than that?
Old 16-06-2006, 11:13 AM
Rhys
Rhys's Avatar
Steve the way the Dollar is at the moment it prob would be that much if your planning on pay by $
Old 16-06-2006, 11:33 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Put some figures to the following and start adding up .
Turbo
loom
ECU
Block
Crank
cams
Verniers
oil pump
WRC Gasket
Long studs
Shells
Leads
Lifters
Gasket set
cambelt
Valve guides
seals
oil feed pipe
water hoses
heater hose
2wd exhaust manifold
TPS Switch
Coil pack
plugs
2nd ignition amp
dipstick tube and bracket
cleaning and plating
rebore
Iskey valve springs
ALS valve
Works throttle housing
WRC inlet manifold
Eight x 803s
pistons
rings
boost hoses
RS500 damper
Old 16-06-2006, 11:40 AM
ECU Monitor Enthusiast
Slide Harvey a wad of cash on the quiet and it will be much cheaper
Old 16-06-2006, 12:03 PM
Richie Russ
Richie Russ's Avatar
I tried that, didnt want any of it !!
Old 16-06-2006, 12:11 PM
le-claw
le-claw's Avatar
Turbo - T4
loom - Not needed - based on orginal being 100%
ECU - Not needed - based on orginal being 100%
Block - Not needed - based on orginal being 100%
Crank - Not needed - based on orginal being 100%
cams - reprofile standard one
Verniers £160
oil pump £150 or £10 for spring
WRC Gasket - Not needed
Long studs - Not Needed
Shells
Leads - Not needed - based on orginal being 100%
Lifters
Gasket set
cambelt
Valve guides
seals
oil feed pipe - Not needed - based on orginal being 100%
water hoses - Not needed - based on orginal being 100%
heater hose - Not needed - based on orginal being 100%
TPS Switch - Not needed - based on orginal being 100% (matched to ECU)
Coil pack - Not needed - based on orginal being 100%
plugs
2nd ignition amp - Not needed - based on orginal being 100%
dipstick tube and bracket - Not needed - based on orginal being 100%
cleaning and plating PMSL
rebore
Iskey valve springs
ALS valve LOL
Works throttle pmsl
WRC inlet manifold - EEVIV will do
Eight x 803s AFPSML - OLD SHIT WAY - 600cc injectors x4
pistons
rings
boost hoses
RS500 damper
Old 16-06-2006, 12:12 PM
Disabled Account
Turbo
loom
ECU
Block
Crank
cams
Verniers
oil pump
WRC Gasket
Long studs
Shells
Leads
Lifters
Gasket set
cambelt
Valve guides
seals
oil feed pipe
water hoses
heater hose
TPS Switch
Coil pack
plugs
2nd ignition amp
rebore
Iskey valve springs
ALS valve
WRC inlet manifold
Eight x 803s
pistons
rings
boost hoses
RS500 damper
You forgot air injectors Mike.......................
