How do these plugs look??
Testing the future
don't tell you anything unless you say exactly what the running condition was when the engine was stopped (i.e. the point at which spark and fuel were cut)
Running fine to be honest, been in the car for a fair few months & ragging sessions.
I took them out to make sure i was getting an accurate TDC reading off the pulleys........
Just thought i'd ask the question.
Look ok to me...certainly no lean cylinder so injectors all working equally.
Plugs can give good info if all the same colour it means everything is equal...for example if one injector was a bit down..one would show leaner regardless...also if a plug failed...also if you had an air leak on one cylinder
People say they not important..but they ARE.
deathrider666
28-09-2015 06:12 PM
