Correct procedure for adjusting Cosworth fuel pressure?
Hi
Can somebody tell me the correct procedure for adjusting the fule pressure on a YB please?
I obviously know that i need to adjust the fuel regulator but the info i am after is at what revs do i take the reading/s and do i do it with the vacum pipe on or off? Also what should the pressure be on a YB running stage 1 Dark blues and 15 psi on a T3??
Cheers Spadge...
Cheers Spadge...
0-60 in 17 seconds (eek)
Spadge,
Here's my preferred procedure: "pick up the phone and book an appointment with Mark Shead"
I have no idea, so here's a free to make up for me being facetious (sp?)
Originally Posted by frog
Spadge,
All done
Was reading nearer 4 bar at idle with the vacum pipe off but i'm guessing it was adjusted upwards for the stage 3 i just removed?
Is sitting bang on 3.5 bar now until i re-fit the vacum pipe and then it drops down to just over 3 is that about right Stu??
Cheers Spadge...
Cheers Spadge...
cossie.087 (05-10-2022)
PassionFords Creator
Originally Posted by JTECHSAFF
should the pressure be different at stage 3? i run one of your closed loop chips Stu...... i set mine up to 3.5bar pipe off
steerfromdarear
28
29-01-2016 06:14 PM
Stu @ M Developments
41
21-08-2015 06:47 AM
Zoggon
10-08-2015 10:39 AM
Escortdriver1
31-07-2015 02:36 PM
