Peeps With ACT Guages.....
A few days ago mine started to read all sorts of different temps... i.e. -0.11c, 56.c etc.....
Some really random temps, now i do know the answer already....... Is it knackered?
Its stopped reading altogether now, just shows -.--c
I'm going to see Mr Rainbird about it, but i wanted to see if its possible to repair first
Originally Posted by BillyCabrio
In a free replacement?
Does he know whats causing it?
I think on mine the conections have come loose because if press the back of the gauge it starts working
Originally Posted by Christian and Beccy
Have you checked the sensor?
Depending on the position, it might be sitting against the side of the pipe or better still, come off and gone through the engine!
Caraholic
As said, make sure the gauge hasn't become unplugged, as it gives the three dashes if it does (and reads hay-wire as it starts to become unplugged).
The other reason that it may read three dashes is if the wire is severed in any way.
All our gauges come with a life-time warranty against manufacturing defects anyway, so if it isn't just a case of it simply becomming unplugged, it will get replaced / repaired FOC .
Originally Posted by AndyST170
if its reading --.- it could have come unplugged from the back of the gauge.
Also
Check that the wire going into the vacuum elbo isnt bent over or broken.
Also
nice amendment, but it think you'll find this to be correct now.
when mine went funny i found it was the plug coming loose from the back of the gauge
youre car looked the nuts larst night not seen one in red and as well as youres for a long time!
whot do you think of the south london rsoc group billycabrio
you going next month
DixieTheKid
11
06-06-2020 11:20 AM
paceo
25-09-2015 08:05 PM
paceo
17-09-2015 12:12 PM
