What causes the ring lands on pistons to crack off?
As some know, i was behind the wheel of my mates skyline at japfest and had a bit of a problem
anyway, we took the enigne out, and got the head off. head looks spot on and the pistons look ok so we think a hone, new set of rings and bearings and jobs a goodun
well, that was until yesterday when i went over and took the pistons out.
piston 1 has a cracked ring land on the inlet side, about 1.5" wide. infact it was in 3 bits and fell out without much hastle. also it looks like the piston skirt has been rubbing on the bore as its quite scored
piston 2 was the same, ring land cracked in the same place, but in 1 piece, bore was not very scored
piston 3, same as 2
piston 4, fook me, it was ok lol!
piston 5 cracked the same as 2, but also the secondary land was cracked, bit between the 2nd compression ring and oil scraper
piston 6, same as 4
soooooooooo
wtf causes them to crack off like that?
and whats with the scoring of cyl 1?
also, how likely is it that it was fucked before i got behind the wheel??
cunts, i knew this was gonna be expensive
piston 3, same as 2
piston 6, same as 4
soooooooooo
PassionFord's crazy fool!
Whatever it is, it seems pretty certain that it was nothing to do with you driving it mate so I'd have to seriously reconsider putting any money in!
My mate owns a 200sx S14a and one of his pistons did exactley the same. Turned out to be the fuel pump on its last legs and wasn't supplying enough fuel and leaned out. Wasn't till he'd just had the new engine in and the fuel pump died. luckily it didn't cost him another engine tho
Super Moderator
i know pistons crack the land under excessive boost ... as i did all 4 in my rst sudden shock of doing 30 psi poxy amal valve fell apart
if it was detting surely there would there not be other marks on the piston crowns ??
but it was on the inlet side????
Originally Posted by fudgeass
eagle, if say you look at the top of the piston on the inlet side, it was about 3/4" from the center line on each side, total about 1.5" long but in the miiddle if you get me? lol
Eagle - yes inlet side.
there were NO other marks on the pistons, the crowns looked 100% fine which is why im not sure it was det tbh.
mike, it was only running about 9 or 10 psi i think
pom, not yet mate, didnt have the camera but next time im over ill take some.
deathrider666
28-09-2015 06:12 PM
