4wd and 2WD Saff Turbos
Yoon
Am i right in thinking that they're both T3's?
But the difference is the flange where it connects to the manifold?
https://passionford.com/forum/viewto...=4wd+2wd+turbo
DEYTUKURJERBS
Originally Posted by Batfink
So thats all that different then?
Different compressor wheel trims too, 4x4 is ever so slightly better.
Im sure Mike will tell you this shortly, but ill save him the phonecall to Harvey and tell you right now
DEYTUKURJERBS
4x4, but not by much, IIRC its just an ever so slightly better flowing compressor wheel.
In fact, id be interested to know from any experts, Stu, Karl, or maybe Mike can ring Harvey what the actual differences are regarding performance of the two.
Yoon
Thanks mate
interesting one if you look at this which you posted the differing numbers mean that they've got differing trim
FORD Sierra RS Cosworth (Turbo T3/TB0361) 1986-87 2WD
FORD Sapphire RS Cosworth (Turbo T3/TB0361) 1988-90 2WD
FORD Sapphire RS Cosworth (Turbo T3/TB0384) 1990-93 4WD
_________________
_________________
TB361 (2wd) has a 55 trim compressor wheel, 60mm exducer, 44.65mm inducer and 6.2mm tip height
..and the TB384 (4wd)has a 60 trim comp wheel, 60mm exducer, 46.5mm inducer and 5mm tip height.
Escort Cosworth TB34 runs a 69mm exducer, 46.8 mm inducer, and is nigh on a TO4B style compressor (which have 70mm exducer) hence why it is known as a T34, it is basically a T3/T4 hybrid, much in the way a 'T28' is a T25 back end, with a very close T3 sized compressor wheel...
All the T3's run the same 59mm turbine wheel and 6mm shaft.
James Porter
28-10-2015 12:17 PM
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
FlashRS
13
31-08-2015 06:02 PM
lockie
31-07-2015 10:03 PM
