Rivnuts - anyone used them?
Team HOTHOT!
Has anyone used Rivnuts for holding something in place?
I need to fix my anti-roll bar to a new location on the BMW, and the logical solution is rivnuts, But I don't want to use them if they are going to be useless and shit themselves at the first sign of a small load on them
The E30 antiroll bar is not like a cossie one, all the loading is on the front wishbones and the arb is there purely as a rollbar, and not a bar to stop the wheels flopping about like on a cossie
so, anyone?
so, anyone?
would drill holes and weld captive nuts on the front ARB personally.
i.e like most are.
dont think rivnuts would be up to it ?
but i've used them loads though, to hold bodykits and trim panels on.
i.e like most are.
Team HOTHOT!
Ryan - there is no way of getting into the chassis leg to be able to put captiv nuts in
hence using rivnuts.
The ARB will be under hardly any load at all due to the way the suspension is designed
Team HOTHOT!
2" - we aint talking a cosworth here, obviously some people have never seen the ARB setup on a bmw E30
Cosworth - antiroll bar stops the wheels flapping about
E30 - the antiroll is there purely as a roll bar, the wishbones and the lollipops stop the wheels flapping about
Can you make a plate with the nut welded to the back, then open up the hole in the car just enough to clear the nut.
Push the nut up through the hole then weld around the outside of the plate?
It will drop the roll bar by the thickness of your plate, but should be ok?
Does that make sense?
Team HOTHOT!
Yep - used some 3mm plate and then welded 2 stud nuts (nuts that are an inch tall) onto them, drilled 2 holes into the chassis, and then welded the plate on, properly firm and secure
chip RS
16
01-12-2014 06:12 PM
