Any idea where I can find a Nissan Bluebird wiring diagram??
Originally Posted by CosRush
Originally Posted by 89XR2
Haynes manual
Haynes manual
Thanks for the reply
Im after the section regarding the alternator. I have 2x wires on a connector and a 6mm stud connection. Im trying to work out where the connections go.
If you have a wiring diagram showing this I'd really appreciate it
Scanner won't play today, but:
Alt terminal B and S both have whtie cables which join together and go direct to battery.
Alt terminal L White /Red wire goes to charging lamp then to ignition controlled +ve.
Alt terminal E Black wire goes to earth
Thanks for that
Ive included a pic, I haven't looked to see if the terminals are actually labelled.
So ive put some on. If you can, will you tell me which is which???
DixieTheKid
23-07-2023 10:16 AM
kosienutter
31
22-08-2015 09:55 AM
ekjim
17-08-2015 08:57 PM
