adjusable tca,s
Old May 31, 2006 | 08:07 PM
Basky's Avatar
Basky
Default adjusable tca,s
do you just adjust these or do you have to adjust the steering arms aswell
and also been told its 3 degrees camber is that right
Old May 31, 2006 | 08:13 PM
GARETH T's Avatar
GARETH T
3 degrees in a road car is alot,,well in a race car its not bad either
it really needs too be set up by a pro
Old May 31, 2006 | 08:15 PM
Rab's Avatar
Rab
Fucking superstar........
3 degress?
You'll never get it going in a straight line!
0.5 degrees is about right for a road car!
Old May 31, 2006 | 08:19 PM
GARETH T's Avatar
GARETH T
Originally Posted by Rab
3 degress?
i know a few racers which are over the 3 degrees mark,,,, knife edge anyone
Old May 31, 2006 | 08:21 PM
Rab's Avatar
Rab
RS Turbos suffer from torque steer as it is. Loads of camber won't help that....
Old May 31, 2006 | 08:36 PM
Basky's Avatar
Basky
its not a road car
Old May 31, 2006 | 08:37 PM
Basky's Avatar
Basky
its not rs turbo either
Old May 31, 2006 | 08:54 PM
marco polo's Avatar
marco polo
baskey
put 6 degresse negative on it if your using it on track mate as a track car car only
and get some centric top mounts for it aswell mate that will do the job
Old May 31, 2006 | 09:52 PM
Basky's Avatar
Basky
cheers marco
Old May 31, 2006 | 09:59 PM
ON-UJAH's Avatar
ON-UJAH
Any change of the TCA will not only change camber, also caster and toe on a MacPherson setup. So you need to get it set up properly with laser alignment.
Old Jun 1, 2006 | 09:09 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
I'm running 3° neg on the front and 2.25° neg on the rear - no issues in a straight line .
Old Jun 1, 2006 | 11:30 AM
Rab's Avatar
Rab
Can you steer? Does it not make it very harsh? Does it not eat tyres like fuck?
Old Jun 1, 2006 | 12:39 PM
Mike Rainbird
Caraholic
Yes, no (I have the correct dampers / springs ) and no (it is predominently used on track, with the road mileage invariably being the driving to and from the track). I have no way of accurately monitoring the latter though, as I do so many track days a year, but the camber doesn't seem to have caused to wear the tyres any quicker ).
Old Jun 2, 2006 | 06:41 PM
marco polo's Avatar
marco polo
baskey
I run a little bit more negative on the rear than Mike but not much more
and a bit less on the front
i had to get a happy meduim because of it being a road car
yatta
May 21, 2016 10:31 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Mark V8
Sep 13, 2015 09:34 AM
mint_s2
Sep 2, 2015 08:58 AM
bassboy
Aug 5, 2015 08:21 AM
