When does your T34 .63 ex start to make positive pressure?
At what rpm does your T34 with a .63 ex housing start to make positive pressure?
Any one got a dyno chart with a boost trace?
Just trying to figure out a spec for an engine I'm working on.
Originally Posted by Stu @ M Developments
Always a mare pal, always a mare and often a long drawn out trial and error process.
If you could sell some of your experience, I would love to buy it!
DEYTUKURJERBS
What advantage would there be of going down to the .55 housing?
How much power is lost? How much better spoolup?
Purely for strength (esp when used with antilag) issues I been considering a T34 when doing new engine for the sheddy SX.
Only 1.8, revving to 7500, usually peaks in the 6500-6900 area.
Thinking a .63 would be a bit wank low down, need the responce really, ALS or not.
Though in all honesty they rubbish as standard even when on boost until they hit 4500 or so, even tho they on boost from really low down, they still fairly gutless for some reason, peak torque is always high
Caraholic
Steve,
You can use cam timing as well to get the turbo to spool up quicker, but then you have another trade-off of moving the power band around (in a similar way to the exhaust housing).
Obviously the skill is matching cams / timing / turbo to get the exact driveability you require.....
DEYTUKURJERBS
Yeah i know mike, but its hard to know the effects without trying that, so for now, its time to work out purely the changes with diff exhaust housings.
In one manor im thinking .48 actually, as if anything with only 1.8 litres its less important than on a cossie to have a big housing, and all .48 cossies ive driven have felt fine, not dead at high rpm or anything, even if they do potentially have less power, hmmm...
Trying to decide if what ex housing to use on a GT30R for 450bhp ZT 8:1
Making some big assumptions, eg T34 and GT have same ex turbine size and trim, same rotating assembly inertia etc
I know the gt is BB cartridge and may spin up earlier but it has a larger compressor wheel so in the world of big assumptions they might even each other out.
I was leaning towards the .82 housing because of the highish CR, and niggling thoughts that i might run into surge if i use the .63 with out mapped boost control?
Just woriied with a .82, I'm not gonna see much action before 4k.... but then i do have the nitrous setup on the ECU for spool up.... ooooh now i know what my missus is going throught when she spends ages staring at all the shampoos in the supermarket!
DEYTUKURJERBS
I cant afford trial and error I can barely afford anything
.55 seems the chickens way out middle ground hopefulness, so thatl do i guess
In all honesty, the power delivery of a big boost .48 housing T34 is absolutley ideal TBH, but if it surges low down then your back to square one arnt you...
Did Someone Mention TUV
The power delivery of a big boost .55 housing is just as good as a .48 one expect the boost doesnt tail off as much or as quickly as the .48
I have just changed form a t34.48 to the .55 and there is no loss of spool-up time and is just as responsive.
Mines a .48 housing and it pulls really well, no feeling of lag what so ever, and as for tailing off, you dont really notice it
Karl mapped my car, peaks at 32psi/ holds 28 psi feels very strong all the way
Zoggon
10-08-2015 10:39 AM
Red_bull
09-08-2015 08:34 AM
