a near impossible game!
check this out. it took me forever to do it.
http://www.donpixel.com/play/en/060327103744/
good luck
good luck
the aim is to make a magic potion. anless u have a few hours to kill i wouldnt reccomend getting into it.
its one of them logic things and everything has to be done in a certain order to complete it.
the answer is loody long to type
let me start u all off.
get top man to get a carrot when standing on the right hand side of the plank.
then open the box under neath it before he eats it. this knocks the carrot out his hand. then 2 bugs come to eat the carrot, click on them to kill them and this clears the shit under the switch.
then eat the other carrot, and get the arrow icon up. drop the right hand side of the crate down and click the arrow.
then click the right hand side arrow so it points to the right.
now click the stick man that just fell. he should walk into the centre room and turn the light on, and the stond under neath will fall.
now click the right hand side arrow and make it point left again and press the door bell.
turn both the ufo bases on using the switches.
now click the ufo next to where the stick man is. straight after click the right hand side yellow dot under the crate. this will make a wheel come out and the ufo should pick it up and drop it on the land mine
the stick man runs into the centre room again so use the door bell to get him out.
he will run to the left and stop. click him again to make him climb up.
use the lower man to change the icon to the shield. now click the switch near the lower man and then click on the lower man.
he should swim accross the water.
bend the pipe thats in the wall upwards.
move the upper stick man to the left of the platform.
now click the ufo and just before it flys off the screen click the shield, followed by the man who just swum accross the water.
u should hit the ufo.
this will freeze the water.
use the shield and the next 2 stones from the pipe to fill the hanging basket.
now turn the light on thats on the left to get kicked accross the water.
turn the switch on again that u just turned off and get the little red bomb to show.
click the bomb and the upper guy will throw it near the water and it will melt.
now click the cog in the middle of the crate, followed by the left had light under the crate.
click the top left window and a carrot will appear. now click the spiders web.
click the spider followed by the bird straight after.
this should make the basket drop onto the wheel u released and they get kicked into the water. this will blow a hole in the side and empty the water.
thats it for now. ur nearly there.
one last tip. try shaking the right hand side of the tree.
Originally Posted by Genesis Engineering
Finished it! rather disappointing ending though
ending is a bit lame, but it is just a free game off some crappy website.
