recognise this hub ???
Old 10-05-2006, 07:57 PM
markk
markk's Avatar
Default recognise this hub ???
does any one know what this hub is off ? some ford of course , but what ? ignore the stud sizes theyve been changed
but i dont know what there from.
the actual relationship between the stut centreline and the bottom ball joint centre line is very 'offset' even more so than a 3dr cossie hub, what would be the effect on the handling with this 'offset' ( as in front hubs)
Old 10-05-2006, 08:27 PM
Doug
Doug's Avatar
Well there not escort/saphire 4x4 ones as they have to little ears that stick out where the strut pinch bolt fits possibly xr4x4 ?
Regards Doug .
Old 10-05-2006, 08:28 PM
markk
markk's Avatar
no not xr either doug, they look like later hubs than sierra pal ?????????
ive got a rough idea but no way to confirm, i thought that someone may know that number ?
Old 10-05-2006, 08:36 PM
Doug
Doug's Avatar
Hmmmmmm ?
Only other thing really is that they are from a front wheel drive escort of some discription as all 4x4 methods have been exhausted in the above quotes unless rs200 4x4 ?
Try giving the part number to your ford dealer in the morning unless some one can cross refrence it for you on here with microcat ?
Regards Doug .
Old 10-05-2006, 08:48 PM
S1
S1's Avatar
It resembles a Focus hub looking at the large offset between the bottom ball joint and the strut mount. Also its got a 97BG code stamped into it from around the time the focus was introduced. Cant identify 100% though.
Old 10-05-2006, 08:49 PM
cossies4eva
cossies4eva's Avatar
looks the same as my mates KA hub's
Old 10-05-2006, 08:50 PM
Doug
Doug's Avatar
Had a look on microsplat number wont go in
Old 10-05-2006, 08:51 PM
Simon
Simon's Avatar
RS2000
Old 10-05-2006, 08:53 PM
S1
S1's Avatar
Just done a quick search and the 97BG is appears to be related to a Focus.
Old 10-05-2006, 08:59 PM
markk
markk's Avatar
the bottom ball joint hole looks to be quite large ?????? way bigger than a cossie
Old 10-05-2006, 09:57 PM
dojj
Resident Wrestling Legend
dojj's Avatar
what are them other 2 lugs for then?
looks a bit too offset for what they hsould be to be honest, that and the huge amount of bracing on the steering lug might mean it's for something more exotic
Old 10-05-2006, 09:59 PM
markk
markk's Avatar
they are very well built , but are ford items, i think th eother lugs may be for abs sensor bracketry ????
Old 10-05-2006, 10:04 PM
Micky The Finn
Former Sponsor
Micky The Finn's Avatar
i know them,they came out of my stores!!
Old 10-05-2006, 10:08 PM
markk
markk's Avatar
fookin ell - who are you ????????????????????? - thought you'd dissapeared off the face of the earth
you will know what i think they are from then tim
im trying to see if i can make any use from them, fookin big cv joints to fit them, but all the splines are massive also, and theyve been bored in the tops to '56mm' , maybe the bottom balls have also
im not going to use them if i cant find out defo what there from
Old 10-05-2006, 10:12 PM
Micky The Finn
Former Sponsor
you could always ask butler,they came from his originally when we cleared him out,m gilman thought they would fit a gravel group A set up as a get you home set up but not to sure,
hey you should have been on the isle of man,averaged the full rally at over 60mph for over 120 stage miles,
was bloody awesome.
Old 10-05-2006, 10:18 PM
Tas662
Tas662's Avatar
Dnt know what they are but theres 2 of them exactly the same on them on the front of the sprite my dad is building
Old 10-05-2006, 10:19 PM
markk
markk's Avatar
ive been before, not been in a few years, i love that place, it motorsport heaven.
how did you do ?
Old 10-05-2006, 10:20 PM
markk
markk's Avatar
i do have the pair , does your dad not know what they are off ?
Old 10-05-2006, 10:26 PM
Tas662
Tas662's Avatar
i'm sure its a sierra of some sort
Old 10-05-2006, 10:35 PM
markk
markk's Avatar
nah definatly not pal, its later than that,
im thinking RS2000 mk5, ?????
Old 10-05-2006, 11:05 PM
S1 Barkham
S1 Barkham's Avatar
They look very similar to erst hubs
Old 10-05-2006, 11:11 PM
markk
markk's Avatar
too big for erst pal, driveshafts would fall through the splines on these !
Old 10-05-2006, 11:22 PM
Micky The Finn
Former Sponsor
oooooooh iam glad you baught these darling!!!!!!
this could be my nite mare!!!!!
Old 10-05-2006, 11:27 PM
markk
markk's Avatar
cheers love
Old 11-05-2006, 04:13 AM
JesseT
JesseT's Avatar
It's a Cougar front hub. 100% sure.
Old 11-05-2006, 06:10 AM
filthyrichie
filthyrichie's Avatar
mondeo
Old 11-05-2006, 06:47 AM
focusv8
focusv8's Avatar
They are Definately NOT Focus Standard, NOT ST , NOT RS.
Old 11-05-2006, 07:51 AM
JesseT
JesseT's Avatar
How can I deactivate the invisible mode on my messages?
Old 11-05-2006, 08:02 AM
the original
the original's Avatar
what was that noise?
Old 11-05-2006, 09:38 AM
Dan@Rapid-Ford
Dan@Rapid-Ford's Avatar
Hi
I think you'll have to run quite an inset wheel with those hubs because the KPI angle looks quite shallow and the steering arm position looks quite high, might give you a bit of bumpsteer unless you lengthen the tie rods or move rack position.
and they remind me of late ultima shape hubs.
cheers
Daniel
Old 11-05-2006, 10:52 AM
It's Czech Mate
It's Czech Mate's Avatar
Mondeo 4x4
Old 11-05-2006, 04:24 PM
Simon
Simon's Avatar
These are off a MK5 RS2000
Old 11-05-2006, 07:28 PM
capri-rs
capri-rs's Avatar
looks like mondeo of some sort
Old 11-05-2006, 07:47 PM
markk
markk's Avatar
it looks like they are indeed mondeo , doug kindly gave me all the measurements to which ive just checked and they look pretty much right
cheers guys,
just one more Q ... whats the diameter of the bottom balljoint stud on the mondeo ?? i.e the bit that goes into the hub ??
cheers
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
Sounds like the man is confident chaps...
Old 11-05-2006, 07:56 PM
Ian M
Ian M's Avatar
cougar and mondeo hubs may be one and the same.!!!
Old 12-05-2006, 09:27 AM
JesseT
JesseT's Avatar
Not sure on the differences, but that part number only goes with Cougar.
aprrrilia
Ford Escort RS Cosworth
10-10-2015 07:14 PM
Sierrasideways
08-10-2015 06:37 PM
fordrallycar
30-09-2015 07:57 PM
IainRS1700T
25-09-2015 06:44 AM
jc1989rs
05-09-2015 08:09 PM
Quick Reply: recognise this hub ???
