oil pressure post
Haynes manual states minimum oil pressure should be 1.0 BAR (14.5PSi) at 750RPM, 2.8 BAR (40.6PSi) at 2000RPM and the oil pressure warning light activates at 0.3 - 0.5 BAR (4.3 - 7.2PSi).
Cold around 60 on start up
How much does the type of oil you use affect this??
im seeing 80psi at cold idle and drops to 40 psi at 60 degrees,
but have not had the car warmer than that yet
worried its gonna drop too low lol
this is using 10-40 mineral oil at the mo
mrmann
20-08-2015 11:24 PM
