compresion test?????????
Old May 4, 2006 | 07:16 PM
iggy gt4's Avatar
iggy gt4
Default compresion test?????????
what should the compression be on a cossie engine??????
just done the test but cant find the info i had saved,,,they are all identical in all 4,,,,,cheers.........
Old May 4, 2006 | 07:34 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
That depends on wheter it is on psi or on bar and what compression your running, but the most critical part is that all 4 cylinders are as identical as possible
Old May 4, 2006 | 07:41 PM
iggy gt4's Avatar
iggy gt4
well they are all the same but the tester could not be done right up as tight as it would go as we cant get in to do it up,so they were all done to the same tightness and all were 128 psi........
Old May 4, 2006 | 07:55 PM
pee vee's Avatar
pee vee
sounds alright i think mate!
Old May 4, 2006 | 08:24 PM
iggy gt4's Avatar
iggy gt4
i hope sooooooooooooooooo
Old May 4, 2006 | 08:28 PM
Doug's Avatar
Doug
An engine will run correctly on anything over 50psi compression not saying that its good fishing to have comp that low but that is a guide
Regards Doug .
Old May 4, 2006 | 08:51 PM
iggy gt4's Avatar
iggy gt4
so 128 psi ao all 4 is a good sign that its ok then...........
Old May 4, 2006 | 08:53 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
I got 11bar on pots 123 and 9.5bar on pot 4
time to take head off i think
Old May 4, 2006 | 09:14 PM
AlexF's Avatar
AlexF
if thats roughly what its ment to be...
did you do a proper test? as in wet and dry?
Old May 4, 2006 | 09:34 PM
Doug's Avatar
Doug
Why is that then just cause you have a lower reading on cylinder 4 does not mean its fooked 9.5 bar equates to 139.65 psi which is good !!!!!
Regards Doug .
Old May 4, 2006 | 09:38 PM
Doug's Avatar
Doug
Regards Doug .
Old May 6, 2006 | 12:52 AM
iggy gt4's Avatar
iggy gt4
no we only done a dry test,will do a wet one sometime this weekend...
TPM961
Jan 15, 2018 10:50 AM
tankybaby66
Feb 6, 2016 02:24 PM
Fiddy
21
Sep 29, 2015 06:10 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
hopper350
Sep 4, 2015 12:53 AM
