head gasket gone with pics
any one shed any light for me i removed the head of my 2wd cossie as it was blowing water out the header tank like a water fall
here are sum pics i cant see any cracks any signs im hopin it was the cometic gasket that failed nothin else hope to get block and head tested tuesday we will see
shit pics cheap diggi cam but u get the idea
[quote="cossie4i"]Nice valve piston contact on the inlet
that's a norm on most yb's
have had a small crack 3/4 down a cylinder b4 also your best off to wait and see what the checks show! number 1 looks abit sus maybe
Originally Posted by Stu @ M Developments
Normal reason for failure is the head bolts coming loose in my experience.
Did any feel a little slack upon removal?
i undone them with a 3/8 ratchet with xtesion bar and 1/4 10mm socket came off easy
now is the head stuffed ?
oh i did a compression test and all were 10/150psi each cly
Hope you get it sorted soon
Steve.
Steve.
Originally Posted by bigal1978
going by pic 5 i think its on its last skim will the head bolts becoming slack mean new head ?
know just that they weren't done up properly!
get the head checked and measured and go from there!
Originally Posted by richm
why do they "come loose" Stu? not torqued up properly in the first place? or just lose tension with age?
but on old car i had all samcos swirl pot baliyes header tank ect now all standered if that would make adiffrence in me not noticeing
The bolts are made to stretch so after fitting and then the engine getting warm the head will expand and the stretch will compensate for that expansion.
If you use old bolts then they would have already stretched and so the head will just pull them thus loosening them from the block once the engine has cooled!
Was that block 'properly' cleaned-up before fitting that cometic gasket? What is left on the top of the block looks like very old debris from a previous standard type gasket to me but it could just be the shonky camera/pics
no it was all new bolts from woodford does seem to be shitty on block but i tho i cleaned it all
ill just take 1 of theses
and hope thre is no more damage
JK12
33
26-04-2021 12:09 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
