COSSIE 4X4 REV NEEDLE QUESTION??????
Hi guys the rev needle is bouncing up and down when accelerating and goes of the scale when revved hard any ideas what it could be ie fooked tacho or something else????cheers
cheers stu i thought it might be something to do with that is it worth unplugging them and spraying electrical spray into the plugs etc???btw u will be seeing me in the summer for one of ur stg3 conversions
Exactly what i do and solves the problem paul.......Its the sensors that run across the back of the engine. I unplugged them, cleaned them and tested....All good You only had to ask
Originally Posted by Stu @ M Developments
Depends what you call "Electrical Spray" For gods sake donst spray something like WD40 in, you will make it worse and more susceptible to problems. Just plug and unplug a few times if you dont have the correct (Expensive) electrical connection cleaner.
other options are the earth connections on the inlet plenum, and coil or ignition amplifier connections.
on 4x4 though, the bulkhead connections are favourite. Pay special attention to the one with the fewer larger wires
if its not the plugs along the firewall then its the phase sensor. Mine did exactly the same thing and it was the phase sensor !
HTH
HTH
Mine is doing exactly the same too. Tried all connections (cleaned a few suspect ones). Still doing it so must be the phase sensor then if i aint missed anything. How much do these cost and availability?
cheers
bri.
cheers
bri.
just searched on burtonpower and its Ł24.95
https://www.burtonpower.com/dets_pro...=08013&PSet=98
(secong product from bottom !)
got mine from woodford but cant find there website. Sure they advertise in PF though
HTH
HTH
before blaming the phase sensor and rushing out to buy a new one, on 4x4 try running the engine without the phase sensor connected and see if the tacho behaviour changes.. If it still does the same then it's not the sensor.. go looking for more poor connections in the coil path or earths on the plenum, engine earth strap, or body earth just in front of the battery.
DixieTheKid
23-07-2023 10:16 AM
CabrioTurbo
01-08-2015 11:04 AM
