lambda sensor/running probs
Old Apr 28, 2006 | 05:28 PM
THE RADMAN's Avatar
THE RADMAN
Default lambda sensor/running probs
trying to sort an intermitent fault and disconnected the lambda sensor on my monte tonight and took it for a run and it drove exactly like it normally does,surely it shuold run like a pile of crap without this? how do you test these out?
Old Apr 28, 2006 | 05:29 PM
GARETH T's Avatar
GARETH T
what car,,, whats the spec....whats your problem
Old Apr 28, 2006 | 05:37 PM
THE RADMAN's Avatar
THE RADMAN
big t esc cos,ahmed st2 usual greens pump 3 bar etc, itll run perfect till youve been cruising at around 50-60mph, for a while then it staRTS to jolt and misfire like its overfuelling,you then have to stop the car as its undrivable and the rev counter goes ballistic and the engine dies,try to start it and it stinks of fuel,but this is the interesting part ,if you leave it to cool down for 15 mins its perfect again for prob another 20 miles or so,ive changed nearly every sensor on the car,all the ignition components etc,that why i wondered about the lambda?
Old Apr 28, 2006 | 05:41 PM
GARETH T's Avatar
GARETH T
guess its on a pectel board? the lambda sensor isnt doing anything its not in the pectel software
ignition amp?
Old Apr 28, 2006 | 05:49 PM
THE RADMAN's Avatar
THE RADMAN
yep its on a pectel,so i can just blank the sensor off then? done ig amp already
Old Apr 28, 2006 | 05:53 PM
GARETH T's Avatar
GARETH T
wiring loom,,, P8 syndrom
Old Apr 28, 2006 | 06:03 PM
THE RADMAN's Avatar
THE RADMAN
am ready to sell car its pissing me off will try changing the map sensor as ive not done that yet,cant see it making any difference though
Old Apr 28, 2006 | 06:06 PM
Jim Galbally's Avatar
Jim Galbally
as per gareth, tis common aparently.
get it to a specialist with a pectel monitor etc. and they'll soon be able to diagnose, as they can watch the inputs live
Damo V's Avatar
Damo V
i guess you dont have the loom plugs still??
Old Apr 28, 2006 | 06:07 PM
cos jon's Avatar
cos jon
Mine is running a stg 3 pectal board and the lamba sensor definately does something !!, if it gets knocked during cleaning the car won't idle at all, may have someting to do wth my overfueling too !
Old Apr 28, 2006 | 06:09 PM
Damo V's Avatar
Damo V
As above, it shouldnt do, not if its the original one bolted into the exhaust hiousing
Old Apr 28, 2006 | 06:14 PM
THE RADMAN's Avatar
THE RADMAN
loom plugs are gone,ive had a pectel monitor rigged up to it and everything was perfect but it obviously wasnt playing up at the time,i hate intermittent faults anyone want to lend me a p8 my lambda deffo doesnt seem to do anything,why isnt it built in to the pectel board then?
Old Apr 28, 2006 | 06:15 PM
cos jon's Avatar
cos jon
Really ?? , well as i mentioned if it gets knocked it starts to play up, definately got the chip in too cos i checked !!
Old Apr 28, 2006 | 06:17 PM
Damo V's Avatar
Damo V
And extra board?
Damo V's Avatar
Damo V
THE RADMAN
As you say try the MAP sensor first..
Old Apr 28, 2006 | 06:20 PM
cos jon's Avatar
cos jon
An extra board mounted above the original ECU PCB board with a ribbon to the original board ??, if thats the one then yeah it has .
Old Apr 28, 2006 | 06:25 PM
THE RADMAN's Avatar
THE RADMAN
yeah sounds like that one jon
Old Apr 28, 2006 | 09:37 PM
THE RADMAN's Avatar
THE RADMAN
will go map sensor shopping tomorrow
gcfcos
59
Oct 6, 2015 05:04 PM
gcfcos
88
Sep 15, 2015 03:48 PM
Si B
Sep 12, 2015 06:49 AM
mint_s2
Sep 2, 2015 08:58 AM
Dahl88
Aug 22, 2015 08:16 PM
